Reasons for formation of counter-rotating vortex inside a bubble |
June 16, 2017, 00:31 |
I am performing a simulation (2-D), where a stationary vapor bubble is placed inside a super-heated liquid (water). The temperature, density, viscosity of the bubble is kept constant. I find that inside the bubble, there are two counter-rotating vortex structures when plotting the velocity vectors. Could anybody help me with what could be the possible reasons behind the presence of these vortex structures? PS 1: I am running the simulation to plot the growth of the bubble as a function of time and compare with the analytical solution. That part is done, and it the results match the analytical ones. PS 2: I am simulating only a quarter of a bubble, as it is axisymmetric, and two vortex like structures are present in one-quarter. Please see the attached image Let me know if you need any other information. Thanks, The_Provost |
June 17, 2017, 05:51 |
Filippo Maria Denaro
Rep Power: 71 |
I have no experience on this specific flow problem, from the pattern of the velocity field seems to me that the bubble is expanding.. This is a steady state solution?
June 17, 2017, 17:30 |
#3 | |
What i do not understand is the presence of the two counter-rotating vortices inside the bubble. |
June 17, 2017, 17:42 |
#4 | |
Rep Power: 71 |
June 17, 2017, 17:47 |
Yes, fluid is at rest initially. I want to confirm if my thinking is correct, i.e. if it is the pressure difference which creates the vortices. Is there any way you can suggest by which I can modify the simulations (may be changing some parameters) to get a proof that it is indeed being caused by the pressure difference? I don't think changing the bubble radius will help, may be reducing the temperature of the liquid?
June 17, 2017, 18:12 |
Rep Power: 71 |
I am not sure about the physics of your problem, you wrote that you take constant temperature and density inside the bubble...pressure is therefore costant...maybe you should give us more details about your formulation
June 17, 2017, 18:14 |
Yes, temperature and density is constant inside the bubble, but the volume is changing (due to increase in bubble size), which makes the pressure change.
June 17, 2017, 18:31 |
Rep Power: 71 |
Therefore the term div v inside the bubble is not zero and you are using a compressible flow model. How do you get pressure? From the state equation it would be constant....
June 17, 2017, 18:35 |
I am using incompressible flow, and solving the continuity, NS, and energy equations for both vapor and liquid phases, I employ a jump condition for the interface which encapsulates the velocity and the pressure change at the interface. When you say div v, you mean the velocity, right? Yes, the divergence of the velocity should be zero as per the continuity equation.
June 18, 2017, 05:15 |
Rep Power: 71 |
I tried to understand your model, but I cannot realize how you can take constant density and temperature and having an increase of the volume of gas with the divergence-free constraint...
For example, this paper shows a differen model https://www.researchgate.net/profile...crochannel.pdf |
June 18, 2017, 05:21 |
#11 | |
June 18, 2017, 05:30 |
#12 |
Rep Power: 71 |
The analytical model is 1D (along r) so that no vorticity can be compared ... you have a 2D model that develop convection and vorticity... You can just compare approximatively fine the surface tension development and the radius increasing...
June 18, 2017, 05:32 |
#13 |
Yes, I am comparing the radius increase, that works fine, I am just trying to determine the source of the vorticity.
June 18, 2017, 05:36 |
#14 | |
Rep Power: 71 |
writing the vorticity equation from your momentum equation shows that it is possible to produce recirculating region by means of the movement of the interface |
June 18, 2017, 13:58 |
#15 |
Jim Breunig
Rep Power: 8 |
Sounds like you may have your answer. I do have to agree with FMDenaro though that you seem to be increasing volume. If mass stays the same, then density must change by simple definition. Not sure incompressible is the way to go, but you know more about your problem than we do. Just giving my own opinion.
June 19, 2017, 10:20 |
#16 |
benoit favier
Rep Power: 8 |
If i understand correctly, some of the surrounding liquids is changing to vapour phase, hence the volume increase without a density change.
As for the vorticity, your buble seems to grow faster at the extremities (along the x axis and y axis), than at the rest of the interface : The shape of your interface is not a quarter of sphere cap. That might be why you have some recirculation. |
vortex entering rotating domain | Yannian | FLUENT | 0 | July 21, 2015 15:22 |
how to apply rotating velocity inside of a domain | yourvahid | OpenFOAM Pre-Processing | 0 | August 8, 2014 14:24 |
how to apply rotating velocity inside of domain | yourvahid | OpenFOAM Running, Solving & CFD | 0 | August 8, 2014 11:11 |
Presenation of vortex strength and velocity concept? | fruitkiwi | Main CFD Forum | 0 | September 26, 2012 22:08 |
direction of circulation inside a bubble | dusky.He | Main CFD Forum | 1 | May 30, 2007 19:16 |
