June 20, 2017, 03:03 |
viscous validation cases
Rep Power: 16 |
Dear all,
I implemented in a finite volume code full implicit and imex semi-implicit schemes for the NS equations at present without any turbulence model. I am looking for 2D/3D laminar viscous validation cases, apart from circular cylinder and flat plate that would show the gain of implicit time integration, especially for imex. Any idea will be greatly appreciated ! Cheers |
June 20, 2017, 03:16 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
This is an exact solution https://pdfs.semanticscholar.org/434...00ac52c18e.pdf I suggest to simulate also the backward facing-step and the lid-driven cavity as wall-bounded laminar flows |
June 20, 2017, 07:31 |
Rep Power: 16 |
Thank you FDenaro for these suggestions. I forgot to mention that I am dealing with the compressible NSE, so I think the lid-driven cavity test would be difficult without preconditionning.
June 20, 2017, 07:43 |
Search for wind turbine cases
A. S.
Rep Power: 17 |
Search for low Reynolds number wind turbine airfoil case, that may laminar. Hoping that you are working on Preconditioned solver or a compressible solver that can work on mach 0.1.
June 20, 2017, 09:00 |
#5 | |
Rep Power: 71 |
laminar flows are characterized by low Re number and that often implies low Mach number, without preconditioning the system is difficult to solve any of these cases |
June 21, 2017, 02:47 |
Rep Power: 16 |
I see, it makes sense. No chance to find a realistic transonic case in laminar regime I guess. Thank you for your answers
June 21, 2017, 11:23 |
Rep Power: 71 |
June 21, 2017, 20:37 |
Arjun
Rep Power: 34 |
removing the post as code was not properly attached.
June 21, 2017, 20:40 |
#9 | |
Arjun
Rep Power: 34 |
Code for the attached paper. |
Viscous forces (interDyMFoam) differ between OF 2.0 and later versions | maxof | OpenFOAM Running, Solving & CFD | 2 | May 30, 2013 04:17 |
Re: Validation Cases for Turrbomachinery | suneesh | Main CFD Forum | 6 | October 7, 2005 03:03 |
Cases validation | prasat | Main CFD Forum | 0 | August 21, 2003 09:14 |
Standard CFD test cases? | Damon Qualski | Main CFD Forum | 1 | April 10, 2003 14:10 |
Compressible Viscous Code vaidation test cases? | Mohammad Kermani | Main CFD Forum | 2 | November 11, 1999 14:22 |
