July 1, 2017, 08:11 |
Calculate Taylor microscale
dilaw meda
Rep Power: 8 |
Hi, i want to generate a good grid for large eddy simulation using the taylor micro scale. I found a relation wich includes reynolds numer and kinematic viscosity and velocity fluctuation. But i dont know how to get velocity fluctuations
July 1, 2017, 10:42 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
The grid filter in LES has to lie in the inertial range, at a lenght scale that is at least one order of magnitude greater than the Taylor lenght. |
July 1, 2017, 11:01 |
dilaw meda
Rep Power: 8 |
I thaught that a grid up to kolmogorov scale is the one wich is pratically a DNS grid
July 1, 2017, 11:13 |
Rep Power: 71 |
The Taylor microscale is the largest of the dissipative lenght scale, at that level of resolution you are practically starting using a DNS grid. The Kolmogorov is the smallest scales but in a practical simulation you will see no relevant differences between the two grids.
July 1, 2017, 11:15 |
#5 | |
dilaw meda
Rep Power: 8 |
July 1, 2017, 11:26 |
Rep Power: 71 |
You are free to set the grid filter at an interval of scales in the inertial range. That is valid for homogenous directions, in case of wall confined flows the grid is as fine as a DNS in case you resolve the BL.
July 4, 2017, 16:37 |
#7 | |
dilaw meda
Rep Power: 8 |
Now ,which is the parameter to caracterise the grid, the smalest size of the edge or the face or the celle , and how i can know if my grid is still in the inertial zone ? |
July 4, 2017, 16:52 |
Rep Power: 71 |
Of course you first need to consider the flow problem you want to simulate...
you can read this paper https://www.google.it/url?sa=t&rct=j...9Xi_qA&cad=rja |
July 4, 2017, 17:01 |
#9 | |
dilaw meda
Rep Power: 8 |
July 4, 2017, 17:19 |
#10 | |
Rep Power: 71 |
As your post starts with the Taylor microscale, you can consider that a grd size greater than that lies at the end of the inertial sub-range. In homogeneous-isotropic flows, the characteristic Reynolds number is computed in terms of this lenght scale. A cell Reynolds number of O(10) is a good choice. In case of confined flows, you have to consider the distance from the wall (the so called y+) and the Reynolds number is based on the wall velocity. Generally, the grid size in LES resolves the boundary layer (at least 3-4 nodes within y+<1), otherwise wall-modelled bc.s have to be used. Your flow problem has both walls and jets in air. Chose the Reynolds that characterizes at the best your problem and follow the above criteria. A more detailed estimation of the grid can be done only when all the geometries and inflow parameters are defined. Then, a relevant issue is the goal of the simulation. This tell you the degree of resolution the grid must have in some region. |
July 5, 2017, 06:37 |
#11 | |
dilaw meda
Rep Power: 8 |
To calculate N the number of nodes In my case i will 2 reylonds numbers to deal with, Relx for wall resolving and Relx for wall modeled likeis mentionned in the topic u sent it to me. This Relx = (velocity*Lx)/visco , velocity i think is inlet velocity right, so what is Lx in bothe cases ( modeled and resolved b.c) length of the nozzles or length of the room in streamwise direction |
July 5, 2017, 06:56 |
#12 |
Rep Power: 71 |
Consider the jets, this is the flow problem you want to be well resolved, right? What about your Re numbers? Then the room is just a closed box wherein you do not need to resolve neither dynamic or thermal boundary layers, right?
July 5, 2017, 08:00 |
#13 | |
dilaw meda
Rep Power: 8 |
[swak4Foam] Problem to calculate grad(U) using swak4Foam | Hugoles | OpenFOAM Community Contributions | 12 | November 24, 2020 10:28 |
calculate friction factor & nusselt number | soheil1991 | FLUENT | 3 | March 11, 2017 09:30 |
calculate velocity difference | helly | OpenFOAM Post-Processing | 0 | June 21, 2016 08:49 |
calculate values for eps and k from Re or u????? | sbar | OpenFOAM Pre-Processing | 5 | August 16, 2010 04:10 |
How to calculate Torque for francis turbine | manish | CFX | 4 | March 15, 2007 02:57 |
