Flow simulation of Brake rotor
Old   July 31, 2017, 18:03
Default Flow simulation of Brake rotor
Swapnil Pandey
sapandey is on a distinguished road
I am trying to simulate a disk brake rotor rotating in free air. I am using the SST model with solid in rotary motion@800 rpm and air at atmospheric pressure. The results show a significant high convective heat transfer co-efficient and no flow through the rotor vanes. Confused with this contradictory result. I am using mesh deformation in fluid domain to couple with rotating solid.
P.S. : I am a structural mechanics person but have to do this for a project. Please pardon for being naive here.
sapandey is offline   Reply With Quote
Old   July 31, 2017, 21:13
Shrirang
shrirang is on a distinguished road
Can you provide more details? Like which package you are using for this simulation? What kind of deformation did you apply?
Is there any other velocity than rotational?
Are you intending to do heat transfer separately after taking htc's from this run?
Sent from my Moto G (4) using CFD Online Forum mobile app
shrirang is offline   Reply With Quote
Old   July 31, 2017, 21:24
Swapnil Pandey
I'm using the CFX module for a CHT analysis. So I'm not extracting the htcs. And there is no velocity other than the rotors angular velocity.
Sent from my Nexus 6 using CFD Online Forum mobile app
Old   July 31, 2017, 21:28
Shrirang
Can you post your convergence plot?
Snapshot of the mesh would also be useful if possible.
Shrirang
Old   July 31, 2017, 21:57
Swapnil Pandey
Here are the snaps for pressure & momentum convergence and turbulence. Also the setup window and mesh. I am pretty sure the setup is wrong. And also I am doing a transient analysis.
Thank you for your reply and help
Old   July 31, 2017, 22:38
Shrirang
Will suggest you one quick change, see if it works.
Let your solid be stationary and give your fluid volume either rotating mesh or rotating frame of reference.
Shrirang
Old   July 31, 2017, 22:41
Swapnil Pandey
Thanks Shrirang.
I will try this and share if it works.
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
How to manage the pressure term in fixed mass flow rate based channel flow simulation sjwon1991 Main CFD Forum 5 July 10, 2017 07:21
rotor 37 choking mass flow rate fluent simulation sehs15 FLUENT 1 January 15, 2015 06:07
mass flow rate issue in supersonic nozzle simulation xkang FLUENT 0 July 31, 2014 16:06
Differences and functions of Solidworks Simulation and Solidworks Flow Simulation? alpharays Main CFD Forum 0 April 19, 2012 03:13
