Is there code to plot stream function from u & v velocities
Like Tree5Likes
Old   August 1, 2017, 07:11
Default Is there code to plot stream function from u & v velocities
kbaker's Avatar
Khalid Baker
kbaker is on a distinguished road
Hello I am searching for a code can plot stream function in terms of u & v velocity components? May somebody guide me to a similar code?
Thanks
Khalid
kbaker is offline   Reply With Quote
Old   August 5, 2017, 11:17
leflix is on a distinguished road
Hi Kbaker,
Here is a piece of code in fortran to compute the stream function from the longitudinal U componnent of the velocity field.
Let me know if you need further details.
Leflix
C************************************************* *********
SUBROUTINE STREAM (U, DY, NI, NJ, PSI)
IMPLICIT NONE
INTEGER NI,NJ, KX,KY, I, J
PARAMETER(KX=512,KY=512)
REAL*8 U, DY,PSI
DIMENSION U(0:KX,0:KY), PSI(0:KX,0:KY)
DO I=0,NI
PSI(I,0)=0.d0
DO J=1,NJ
PSI(I,J)= PSI(I,J-1) + U(I,J)*DY
END DO
END DO
RETURN
END
leflix is offline   Reply With Quote
Old   August 5, 2017, 12:16
kbaker's Avatar
Khalid Baker
Thanks Leflix for the reply. Actually I not looking for a fortran program I want to draw the stream function in Tecplot code? Do you have experience with it?
Khalid
Originally Posted by leflix View Post
Hi Kbaker,
Leflix
IMPLICIT NONE
REAL*8 U, DY,PSI
DO I=0,NI
PSI(I,0)=0.d0
DO J=1,NJ
END DO
END DO
RETURN
END
Old   August 5, 2017, 12:21
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
That shoud be part of tecplot already... at least I recall it was. You should read the manual if that feature is not particularly immediate to reach.
sbaffini is offline   Reply With Quote
Old   August 5, 2017, 12:26
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
It is very easy, you have just to activate it in the menu and then click on a point in the field to have one streamline.
http://www.tecplot.com/blog/2014/10/...article-paths/
mariam.sara likes this.
FMDenaro is offline   Reply With Quote
Old   August 5, 2017, 15:16
Ok ! Yes you have to upload your velocity field in 4 columns
x y Ux Uy
Then you activate streamtrace and as Filipo mentioned it click on a point you will have a streamline there. Yiu can also trace a line along the two opoosite corner of your domain and it will display sveral streamlines. Check out the documentation of tecplot.
Leflix
Old   August 5, 2017, 16:44
kbaker's Avatar
Khalid Baker
Attachment 57592Thanks leflix and Filippo for the information. Leflix I already did a file with four coloums i.e. x y u v I saved it as general text file when I open it in Tecplot as a text and in order to activate streamtraces I need to do triangulation. The problem when I attempt to do 2D triangulation it give me error as the attached pict? so what the problem ?
Khalid
Old   August 5, 2017, 16:56
Is your grid structured or unstructured ?
Old   August 5, 2017, 17:04
mariam.sara is on a distinguished road
I have same problem
mariam.sara is offline   Reply With Quote
Old   August 5, 2017, 17:08
kbaker's Avatar
Khalid Baker
Its structured grid I use meshing code to make the mesh and solve the problem using CFX code. My geometry is a sqaure cavity.
Old   August 5, 2017, 17:12
Check first if the data are loaded correctly and show the grid to see if it appears structured
Old   August 5, 2017, 17:13
so you don't need to make a triangulation. Check how to format the data for structured grid. You have to loop on j and i , the number of nodes in j direction is NJ, and NI the number of nodes in the i direction.
write(1,*)'zone i=',NI,', j=', NJ,', F=POINT'
do j=1,NJ
do i=1,NI
write(1,*) Xc(i,j), Yc(i,j), U(I,J), V(I,J)
end do
end do
FMDenaro and mariam.sara like this.
Old   August 5, 2017, 17:15
leflix is correct, the first line is the header, the you can activate directly the streamtracer without triangulation
Old   August 5, 2017, 17:23
kbaker's Avatar
Khalid Baker
I am really not sure about the type of mesh structured or not? I uploaded some picts for it?
do j=1,NJ
do i=1,NI
end do
end do
Old   August 5, 2017, 18:22
It is definetely a structured grid. You can access to every nodes with 2 indices i and j.
Leflix
Old   August 6, 2017, 02:13
kbaker's Avatar
Khalid Baker
Dear Leflix As I think the part of program you sent it is in Fortran? right? I need to ask in order to apply it to the data I need to save the data in a file then call it by open? my question is do I need separate file for x,y,u and v or I store all of it in one file (as I stored it now see attached dat file which I arrange starting from left x,y,u,v)?
What part of program should be written before this statement:
Leflix
Old   August 6, 2017, 07:20
Hi Kbaker,
You should write all the data in the same file
x, y, U, V
just at the begining of the file write this:
VARIABLES= "X","Y", "U","V"
zone i= 100, j= 100 , F=POINT
assuming you have 100 grid nodes in i direction and 100 grid nodes in j direction. (this should be automatized when generatin the file in your code)
and then write
x,y, U,V as you did in your file.
name the file with .plt as extension rather than .txt so that Tecplot can recognise it and open it directly. Name it velocity.plt seems not bad.
Old   August 6, 2017, 07:51
Is this code need to be programed in Fortran language?
Old   August 6, 2017, 07:57
kbaker's Avatar
Khalid Baker
I am really confused about the program. Now I am started with writing a program to just reading the variable in a one matrix and print it as below:
IMPLICIT none
real X
integer i,j
DIMENSION X(5000,4)
open (unit = 1, file = "f:\velo.txt")
open(unit = 2 , file = "d:\fortran programing\res1.txt")
do i=1,4624
do j=1,4
Read(1,*) X(I,J)
enddo
enddo
do i=1,4624
write(2,*) (X(I,j),j=1,4)
enddo
stop
end
I just want to test the program validity in printing the variables but it tell me error: run time error F6501: Read(F:\velo.txt)
-end of file encountered
What the problem with my data? I attached the dat file?
Hi Kbaker,
x, y, U, V
and then write
Old   August 6, 2017, 08:06
First how many points do you have in x direction (i) and in y direction (j) ?
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 10:51
Simple stream function vorticity formulation for flow past a rectangle [Matlab] a99 Main CFD Forum 2 March 5, 2016 04:04
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
