September 12, 2017, 02:04 |
Meshing Size Determination Factors
Makarand
Sir, what are the factors to be considered while selecting meshing size.
I want to do meshing of bus & there are total 222 elements in it, so what is the meshing size to be selected for it. |
September 15, 2017, 03:07 |
What is meant by 222 element. For maximun size we take length of our characteristics feature while for minimum mesh size we try to capture geometric feature accurately. Again if we see our mesh in proximate surfaces to see if there are sufficient finite volume element to solve the equation. It is a whole iterative process instead.
[blockMesh] edges not aligned with or perpendicular to non-empty directions | ynos | OpenFOAM Meshing & Mesh Conversion | 6 | March 26, 2020 15:02 |
[ICEM] Effect of globle mesh size and mesh independency | sujay | ANSYS Meshing & Geometry | 20 | September 29, 2019 07:36 |
[GAMBIT] meshing trouble: "WARN: size function is already associated with lower entities"... | Wai Yan Thet Paing | ANSYS Meshing & Geometry | 2 | November 16, 2015 01:24 |
[ICEM] Help with fixing imported IGES model | siw | ANSYS Meshing & Geometry | 24 | August 24, 2010 11:22 |
OpenFOAM 13 AMD quadcore parallel results | msrinath80 | OpenFOAM Running, Solving & CFD | 1 | November 10, 2007 23:23 |
