Simulating solid particles in fluid using VOF method |
October 15, 2017, 16:53 |
Mohammad Sobhani
Rep Power: 13 |
I want to simulate motion of solid particles in a newtonian fluid. Is it possible to define a fluid with high viscosity and high surface tension instead of solid particles and then solve the problem with VOF multiphase model?
October 16, 2017, 00:20 |
Uwe Pilz
Rep Power: 15 |
This approach is possible but has limitations: Fluid "particles" of this properties get always round. You cannot simulate any effects which depend on the shape of the particles.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
October 16, 2017, 02:28 |
France - Alsace
Rep Power: 8 |
You have to use FSI (Fluid-solid interaction) to solve phenomena so you have te define degrees of freedom to particles but overset mesh is needed in this case of simulation |
solid particles, vof multiphase |
chtMultiRegionFoam connection between solid and fluid region of heat exchanger | ahab | OpenFOAM | 1 | December 18, 2019 00:37 |
Simulating discrete solid phase inside a continuous fluid phase | hosseinamir71 | CONVERGE | 1 | August 31, 2017 16:02 |
[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ? | RPjack | ANSYS Meshing & Geometry | 2 | August 27, 2015 09:33 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
heat conducting solid within a fluid medium? | sieginc. | STAR-CCM+ | 1 | February 19, 2012 11:48 |
