Mesh influence in convergence
Old   September 29, 2017, 10:44
Default Mesh influence in convergence
oswaldo borjas
oswaldob22 is on a distinguished road
Hi there,
Im a beginner in CFD simulations. For a final project, i am modeling a turbulent flow across a pipe (CS). In the middle of pipe, exist a heat flux
I need to find the output values of temperature across the pipe.
In the beginning, i started with a 3D model. Then in order to make simple the model, i change the 3D model to 2D model.
The problem is when i apply a fine mesh (refining the most important study areas) the solution never converge, eventhough if i set to 10000 the iteration number).
In the other hand, if i set a coarse mesh the solution converge (around 500 iterations)
I dont know if the problems is because of Boundary conditions or the course of mesh
BC
The inner diameter of pipe is 58.8 mm
Velocity inlet : 25.78 m/s
Pressure outlet: 1 bar
Heat Flux:4200 W/m2
I am using a K-Epsilon standard model and the fluid is AIR (ambient conditions). I reviewed all the input parameters to be sure if i am making a mistake but it seems everything Ok.
The main questions is:
Is the refine of mesh an important value for the model convergence?
I think the most important values are the BC parameters
Thanks in advance!
Coarse mesh
https://www.dropbox.com/s/oiwepa06z3...0mesh.jpg?dl=0
Fine mesh
https://www.dropbox.com/s/i4ixtw6kny...203mm.jpg?dl=0
No convergence
https://www.dropbox.com/s/agm9jxz0q5...encia.jpg?dl=0
oswaldob22 is offline   Reply With Quote
Old   October 3, 2017, 09:13
power
enginpower is on a distinguished road
Did you check quality parameters of mesh?
enginpower is offline   Reply With Quote
Old   October 3, 2017, 09:26
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
That could also depend on the type of RANS model you are using
FMDenaro is offline   Reply With Quote
boundary conditions, convergence, mesh, pipe, refine
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Influence of schemes on mesh size, orientation and type in a convective flow field Tobi OpenFOAM Verification & Validation 8 July 16, 2017 08:01
Convergence problem with mesh? tareqkh Main CFD Forum 0 July 13, 2016 17:38
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
