October 5, 2017, 08:28 |
Mesh symmetry problem
Rep Power: 12 |
Hello everyone,
I知 modeling a micro modular reactor subchannel, which has a hexagonal geometry, but I think we can see this as a cylinder to understand my problem. I ran a simulation and I had some great results in comparison with analytical ones. But it took really long time, so now I am trying to model just a part of the geometry, since it has some symmetries. For example, I can model 1/6 of the hexagon. But, using the same mesh refinement (I did a mesh convergence study to the whole subchannel) I知 not finding the same pressure drop: 0,027 MPa (originally) against 0,029 MPa. I tried to increase the refinement by 5 times, but the result does not change. Do you have any idea what the problem might be? Please. Thanks, Felipe |
October 5, 2017, 10:10 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
I assume that you have no bug in setting periodicity in the BC... However, modelling only 1/6 of the domain is also an assumption on the flow solution. Are you sure that the original complete domain gave you a solution that confirms this assumption? |
October 5, 2017, 10:24 |
Rep Power: 12 |
Thank you Denaro,
I am considering Symmetry regions on every fluid face (one because it is a subchannel of a rod bundle, and two because of the 1/6 symmetry). I don't think I have problems with that, I have been working with rod bundles for a while and I am not considering secondary (transversal) flows, for example. |
[Other] Mesh Importing Problem | cuteapathy | ANSYS Meshing & Geometry | 2 | June 24, 2017 05:29 |
Mesh is doing some problem | prwl120 | FLUENT | 2 | May 21, 2015 14:05 |
[ICEM] problem in mesh output | mehrzad | ANSYS Meshing & Geometry | 2 | December 10, 2014 18:07 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
