October 24, 2017, 04:03 |
Ducted propeller- Wall/Interface?
Ben
Hello all,
I'm pretty new to the CFD so I'll appreciate if you would try to explain the things as simple as you can. I've tried to simulate a propeller without a duct. I've created 2 domains, one is the surrounding fluid and the other is a smaller domain which rotates (using moving ref frame) close to the propeller. In this case I've managed to set the interfaces. Now I'm trying to add a duct (axial cylinder around the propeller) to the model. The duct isn't connected to the propeller, there's a small gap between the inner diameter of the duct and the diameter of the propeller. I've tried to do the same thing as with the non-ducted propeller geometry: 1. Subtract the propeller from the inner (rotating) domain. 2. Subtract the duct from the surrounding domain. 3. Subtract the inner (rotating)+ propeller from the surrounding domain. The problem that I've faced is that I can't use the duct both as a wall and a interface between the surrounding domain and the inner domain. Thank you in advance. |
[ANSYS Meshing] Ducted propeller MRF issue | cagriaydin | ANSYS Meshing & Geometry | 8 | January 28, 2020 09:49 |
meshing ducted propeller | amateurCFD | ANSYS | 1 | April 1, 2016 13:06 |
Streamline simulation for Ducted Propeller | bmaldi | STAR-CCM+ | 2 | September 20, 2015 03:20 |
simulation of water flow though a ducted propeller | spacewatcer | FLUENT | 0 | April 22, 2009 09:52 |
Ducted propeller, Boundary conditions | Johannes | FLUENT | 0 | May 7, 2008 09:21 |
