Ducted propeller- Wall/Interface?
Old   October 24, 2017, 04:03
Default Ducted propeller- Wall/Interface?
Ben
Ben12 is on a distinguished road
Hello all,
I'm pretty new to the CFD so I'll appreciate if you would try to explain the things as simple as you can.
I've tried to simulate a propeller without a duct. I've created 2 domains, one is the surrounding fluid and the other is a smaller domain which rotates (using moving ref frame) close to the propeller. In this case I've managed to set the interfaces.
Now I'm trying to add a duct (axial cylinder around the propeller) to the model. The duct isn't connected to the propeller, there's a small gap between the inner diameter of the duct and the diameter of the propeller. I've tried to do the same thing as with the non-ducted propeller geometry:
1. Subtract the propeller from the inner (rotating) domain.
2. Subtract the duct from the surrounding domain.
3. Subtract the inner (rotating)+ propeller from the surrounding domain.
The problem that I've faced is that I can't use the duct both as a wall and a interface between the surrounding domain and the inner domain.
Thank you in advance.
Ben12 is offline   Reply With Quote
[ANSYS Meshing] Ducted propeller MRF issue cagriaydin ANSYS Meshing & Geometry 8 January 28, 2020 09:49
meshing ducted propeller amateurCFD ANSYS 1 April 1, 2016 13:06
Streamline simulation for Ducted Propeller bmaldi STAR-CCM+ 2 September 20, 2015 03:20
simulation of water flow though a ducted propeller spacewatcer FLUENT 0 April 22, 2009 09:52
Ducted propeller, Boundary conditions Johannes FLUENT 0 May 7, 2008 09:21
