December 22, 2017, 19:40 |
calculation activities, execute commands
Andy
Rep Power: 8 |
I want to use the execute commands in Fluent. This tool is give under "calculation activities" in the setup. You can define a command, or a macro, which will be executed at a certain itaration/time step. Because I use an extern cluster it is not possible to use macro. So I want to type in the commands. For example to change the mass flux in the inlet. The language/syntax should be like in the TUI. So: define/boundary_conditions/mass-flow-inlet/... I don't know how to finish this line!! If I try to change the value through the TUI, after mass-flow-inlet and the inlet name a bunch of parameters are listened, where I have to click enter till the muss flux appears. Through a TUI it's easy. But how do I write the command fot the calculation activities? Can someone give me an example for changing massflux? Thank you |
calculation activities, execute commands |
Transfer output data as input for second calculation | mannobot | Main CFD Forum | 3 | December 7, 2018 09:37 |
Propeller calculation | toil | CFX | 15 | May 22, 2017 04:06 |
Determining the calculation sequence of the regions in multe regions calculation | peterhess | OpenFOAM Running, Solving & CFD | 4 | March 9, 2016 03:07 |
Quick Question on Calculation Time | Davitt | COMSOL | 0 | January 14, 2016 14:16 |
Defining output as input for second calculation | mannobot | FLUENT | 1 | June 2, 2010 04:20 |
