January 7, 2018, 14:50 |
references on high order methods
Rep Power: 16 |
Dear all,
I am looking for references where I could find comparisons for discontinuous flows between classical finite volume 2nd order schemes and higher order schemes such as eno, weno, kexact, DG etc. I am looking for these classical test cases such as shock-acoustic interaction in 1D, supersonic step, double mach, Rayleigh-Taylor in 2D. I am finding it hard to encounter articles where both approaches low-order/high-order are fairly compared on complex flows involving shocks and contacts, in terms of accuracy and computational speed. edit: on unstructured meshes would be ideal Many thanks, François |
January 7, 2018, 15:07 |
Filippo Maria Denaro
Rep Power: 71 |
Have you tried to search in the publications of T.Barth?
January 7, 2018, 17:36 |
Rep Power: 16 |
Thank you for your suggestion. I will have a look to other papers from him. I read one of him from 1993:
Recent Developments in High Order K-Exact Reconstruction on Unstructured Meshes where he applies his limiter to the full taylor exansion but the comparison to 2nd order limited is biased if I understood it well because 3rd order reconstruction is obtained by splitting the current mesh into sub-volumes (fig 4) hence resulting in smaller control volumes |
January 8, 2018, 00:04 |
A good reference on least square method
A. S.
Rep Power: 17 |
January 8, 2018, 09:40 |
Rep Power: 16 |
thank you for your suggestion, I will have a look to this author
January 8, 2018, 11:07 |
Rep Power: 71 |
Of course, you can find many useful references in the book of Leveque
Lattice Boltzmann methods for high Reynolds number flows | Osama Maklad | Main CFD Forum | 2 | July 21, 2015 18:40 |
High order methods in commercial use? | cfdnewbie | Main CFD Forum | 5 | January 12, 2012 05:51 |
High order elements | pankos | Main CFD Forum | 1 | February 1, 2011 08:56 |
Implicit, high-order methods for Incompressible NS | Dave Rudolf | Main CFD Forum | 10 | January 29, 2007 10:13 |
High order compact finite difference schemes | Mikhail | Main CFD Forum | 6 | August 5, 2003 10:36 |
