January 21, 2018, 11:51 |
capillarity question.
Katt
Rep Power: 8 |
Greetings;
I am trying to understand "capillarity". 1. Does the surface tension force act only on the walls of a model or acts all along the interace between fluids? 2. I tried a tutorial case in OpenFoams multiphase solver (using volume of fluid) and whenever I output the capillary force: the values on the wall are 0. Whereas they have values in the internal cell faces where there is an interface. Further, when we say capillary forces as: (perimeter of interface)*ST*cos(contact angle) is that a general value? Which we should get numerically after summation of the capillary forces acting all along the interface? K |
January 21, 2018, 14:14 |
Rep Power: 8 |
Capillary force acts along the interface and it is proportional to interface curvature, so its nomal that you find it into internal cells. The vof solver caluculates the curvature as the divergence of volume fraction gradient normalized by the gradient'module, so if you have a volume fraction gradient then you have a force in the owner cell. |
January 21, 2018, 14:18 |
Rep Power: 8 |
Moreover, if you want a general formula, the capillary force is caluclated ans the integral along the interface of ST*curvature*normal. For simple cases it reduces to the one that you have written.
January 22, 2018, 12:55 |
Saideep
Rep Power: 12 |
It could be more like you misunderstood textbook pictures which show the capillary force acting on the wall. You can realize the intention of the figures, where the authors generally want to say that the contact angle plays a crucial role in determine the magnitude of the force as well. |
Question about symmetry in Autodesk Cfd 2016 | ecto | Autodesk Simulation CFD | 0 | October 20, 2015 04:16 |
small question about the functionalities of topological changes in OpenFoam | ngj | OpenFOAM Running, Solving & CFD | 2 | February 28, 2013 10:02 |
Question Re Engineering Data Source | imnull | ANSYS | 0 | March 5, 2012 13:51 |
internal field question - PitzDaily Case | atareen64 | OpenFOAM Running, Solving & CFD | 2 | January 26, 2011 15:26 |
Poisson Solver question | Suresh | Main CFD Forum | 3 | August 12, 2005 04:37 |
