source term
Old   January 24, 2018, 02:30
Default source term
yassi271 is on a distinguished road
I need to add following term to energy equation as my energy source in openFoam:
Se=-rho*cp*Gamma*Uy
rho=density
cp=specific heat
Gamma=laps rate
Uy=y_component of velocity
also i need t add a source term to momentum and continuity equation like:
Sm=c*f1(y)
c= dimensional constant
f1(y)=a function of y-coordinate
it is straight-forward in FLUENT, but after several day searching , i couldn't find any answer in openfoam
yassi271 is offline   Reply With Quote
Old   January 24, 2018, 12:38
Lucky
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
It requires you to do some OF coding yourself. Two ways that I know of:
Modify the solver directly and re-compile it. So look in E***.H depending on what form of energy equation you are solving. Then somehow modify UEqn.H to your needs.
The other approach, probably more elegant, is to make an fvOptions dict.
However, I'm not sure if adding a mass and momentum source is as straightforward as this seems, how does the pressure correction equation change? One would need to check.
LuckyTran is offline   Reply With Quote
Old   January 24, 2018, 14:32
thanks luckytran,
In atmospheric boundary layer, in order to resolve gravity waves i should add those source terms in upper boundary layer. In fluent they worked very well.
Source Term due to evaporation in energy transport equation styleworker OpenFOAM Programming & Development 3 September 7, 2022 03:09
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X gschaider OpenFOAM Installation 136 October 10, 2017 17:25
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 09:07
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
