January 29, 2018, 05:58 |
Hybrid RANS/LES flat plat
SAM
Rep Power: 14 |
Dear all
I am developing a hybrid RANS/LES (gamma_Retheta IDDES) for flat boundary layers. The problem is that in the profile of skin friction (Cf), there is a sharp decay after transition (blue line is IDDES, symbols are the experiment and the green line is RANS), which means the turbulence deteriorate in that small region. Can someone help me solve this problem with a good suggestion? I do appreciate any help. H N |
January 29, 2018, 06:37 |
Filippo Maria Denaro
Rep Power: 71 |
First, I suggest to plot the x-axis in terms of the Re_x value.
Hovever, I am not sure to understand what you want, you cannot use RANS for studyng transition from laminar to turbulent conditions over a flat plate. Then, you should check your grid resolution, are you resolving correctly the BL? |
Flat Plate Boundary Layer Height | kennedy1992 | Fidelity CFD | 7 | February 24, 2016 04:45 |
Flat plate analysis in cfx | hamed.majeed | CFX | 14 | February 4, 2015 07:07 |
Hybrid RANS/LES models | EMolina | SU2 | 20 | October 26, 2014 12:38 |
hybrid RANS/LES in CFX? | Hao | CFX | 4 | February 25, 2009 03:38 |
Hybrid mesh generation | Jake | Main CFD Forum | 2 | April 21, 2007 14:27 |
