January 31, 2018, 09:18 |
Loop Seal Aeration simulation
Pedro Elias
Hello Everyone
I've been working on a simulation of a loop seal valve in a Circulating Fluidized Bed. The main problem I've been having is that somehow the sand inside the recycling chamber is falling through the air distribution plate, even though there is an air flow through there. This simulation is based on an real CFB in my university, ant in the real loop seal there is a grid, like a filter, that prevents direct contact between the sand and the air distributor. I've tried using the porous zone function in the fluent, but somehow sand is still falling through. One thing that should be worth mentioning is that my geometry and mesh is only related to the space occupied by the fluid, not including the solid parts of the valve, does that makes any difference? |
cfb cfd loop seal |
Simulation FPEs - turbulence for transient and steady-state? | DaveR | OpenFOAM Running, Solving & CFD | 5 | March 5, 2017 15:06 |
CFD simulation of Archimedes Screw Turbine for prediction of rate of aeration. | shankar_nith | Main CFD Forum | 0 | September 14, 2016 07:42 |
Simulation of high pressure diesel injector - all phases compressible with cavitation | fivos | CFX | 4 | July 30, 2015 06:48 |
Huge file sizes when Running VOF simulation | aarratia | FLUENT | 0 | May 8, 2014 12:27 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 10:06 |
