March 7, 2018, 19:53 |
Slip or Non-slip conditions?
Rep Power: 8 |
Dear CFD fellows!
Can I impose non-slip conditions at wall in an Euler equations solver (meaning, compressible and inviscid flow), or I MUST use slip conditions? If latter, how do I impose slip conditions? I know for normal velocity, we have vn = 0; and for other primitive variables, we have drho/dn = 0; dE/dn = 0 (dp/dn = 0); but we still need two more. nsi |
March 8, 2018, 00:56 |
Uwe Pilz
Rep Power: 15 |
It depends of what you try to simulate.
If thee are real walls, you need to use a non slip b.c. If you have simply the borders at the region you want to simulate, but in reality the area/volume is more extended, use slip b.c.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
March 8, 2018, 04:11 |
Filippo Maria Denaro
Rep Power: 71 |
Euler equations are first order, therefore only one BC.s can be prescribed to be the problem well posed. If you would set no-slip BC.s how do you ensure the body is not-permeable?
March 13, 2018, 12:17 |
Boundary conditions for Euler equations
Selig
Rep Power: 10 |
Maybe this is obvious, but I would like to note that in implementing no-slip BC, it is not the same as in incompressible NS. For incompressible NS (assuming a collocated grid) you can literally set . In my experience with compressible Euler equations you must use interpolation with a layer of ghost cells otherwise you run into problems. For the left BC: In my experience (which could be due to programming errors) simplying setting is not sufficient since you have to take into account the other primitive variables.
March 13, 2018, 15:54 |
Rep Power: 8 |
March 13, 2018, 23:09 |
BC for Euler equations
Selig
Rep Power: 10 |
Unfortunately, I am not experienced in the immersed boundary method. I would look at the CFD book by Anderson or Versteeg. They might discuss type of situation. With that said, if I recall correctly Versteeg deals with more incompressible flow numerics.
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
No Slip Boundary conditions | lawrencelkl | OpenFOAM Running, Solving & CFD | 4 | June 19, 2018 01:33 |
water penetrates the wall under slip boundary condition | xiaor1 | OpenFOAM Pre-Processing | 1 | December 17, 2015 13:26 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Navier-Stokes with slip Boundary conditions | Leo González | Main CFD Forum | 5 | December 23, 2000 16:16 |
