Initial Boundary condition of velocity for flow over the cylinder by LES simulation |
March 19, 2018, 03:06 |
I am simulating flow over the cylinder with LES in OpenFOAM. I am not sure about the initial boundary condition for velocity at the inlet. I ran the simulation with the fixed uniform velocity at the inlet but there is overprediction in Lift and Drag coefficient. For this case, the Turbulent intensity has been kept same as experimental data. Simulation: Cd=1.48, Clrms=0.808 Experiment: Cd=1.14 Clrms=0.36 Please provide me some suggestion to overcome this problem |
March 19, 2018, 03:43 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
First, you need to ensure that your grid is enough refined over the cylinder. What about dx+,dy+,dz+? Then, the inflow in LES should be properly generate being the turbulent field 3D and time-dependent. You can read this issue in the book of Sagaut. Alternatively, you could assume a laminar inlet with a small fluctuations superimposed and set the inlet far from the cylinder in such a way to let the flow physically correlating. |
Problem with chtMultiregionFoam radiation boundary condition | baran_foam | OpenFOAM Running, Solving & CFD | 10 | December 17, 2019 17:36 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
HeatSource BC to the whole region in chtMultiRegionHeater | xsa | OpenFOAM Running, Solving & CFD | 3 | November 7, 2016 05:07 |
SLTS+rhoPisoFoam: what is rDeltaT??? | nileshjrane | OpenFOAM Running, Solving & CFD | 4 | February 25, 2013 04:13 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
