March 20, 2018, 03:46 |
Steady Laminar Backwards Facing Step
E
Rep Power: 8 |
Hello!
I am writing code to solve 2D Steady Laminar Backwards Facing Step problem for Reynolds number up to 400 through finite differences with dimensionless 2D Navier-Stokes equations. The boundary conditions are the following: Inlet: Parabolic profile for u, v=0, pressure calculated by the pseudo-compressibility continuity equation. Walls: u=v=0, pressure calculated by the pseudo-compressibility continuity equation. Outlet: θu/θx=0, θv/θx=0, p=0. I am running the code but after the step the flow has an upwards direction where it would be expected going downwards with recirculation area. Any help? Thank you very much. |
March 20, 2018, 03:59 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
I suggest to debug the code to find some bugs... have a look to the pressure equation that must have suitable Neumann BC.s |
March 20, 2018, 04:03 |
E
Rep Power: 8 |
Thank you FMDenaro.
Are the boundary conditions that I am using correct except for the pressure boundary conditions? |
March 20, 2018, 04:06 |
#4 | |
Rep Power: 71 |
I suggest not to use the constant pressure at the exit but the condition derived from the fact that you supposed du/dx=0 in the continuity equation evaluated at the exit. You will also easily see that you get v=0 along the outflow. |
March 20, 2018, 04:17 |
E
Rep Power: 8 |
Thank you. I will check it.
March 20, 2018, 04:47 |
Rep Power: 71 |
Are you using a second order central discretization on staggered grid?
March 20, 2018, 04:53 |
E
Rep Power: 8 |
I am working with finite differences and in some cases with second order central discretization and in another cases with forward or backward discretization.
March 20, 2018, 05:21 |
Rep Power: 71 |
what about the colocation of the variables on the grid?
March 20, 2018, 06:40 |
#9 |
E
Rep Power: 8 |
March 21, 2018, 00:12 |
Bfs
#10 |
Selig
Rep Power: 10 |
March 22, 2018, 15:09 |
#11 | |
E
Rep Power: 8 |
I wrote SIMPLE algorithm for the same problem but the velocity field is not the expected. Is there any advice about the correct boundary conditions of the problem? Thank you. |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
p_rgh initial residual no change with different settings | manuc | OpenFOAM Running, Solving & CFD | 3 | June 26, 2018 15:53 |
Long simulation time (Backward Facing Step) | nskelly | OpenFOAM Running, Solving & CFD | 3 | March 6, 2018 10:59 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 10:08 |
Setup for laminar backward facing step (bfs) | quarkz | Main CFD Forum | 13 | September 30, 2005 09:51 |
