April 11, 2018, 10:00 |
Pressure Ration Explanation
Peter Silie
Rep Power: 8 |
Hi all,
you can see attached the total pressure ratio along the span of a rotor blade of an axial compressor. I am sure the calculation is right but I cannot explain why the ratio becomes bigger and bigger in the hub region and then it decreases suddenly more and more and gets a minimum in the tip region. Is a possible explanation that I defined a no slip wall, so the static pressure (and the total pressure) has its maximum there. Ans along the span the work of the blade is smaller and smaller and thats why the total pressure as well? Greetings |
April 11, 2018, 13:16 |
Lucky
Rep Power: 66 |
It is hard to say without actually seeing what the hardware looks like. For any blade, the tip and root move at different linear speeds so that the blade contour must be designed to achieve any particular distribution of flow parameters. Your absolute and relative blade angles (alpha's and beta's) determines what that looks like.
Also, if you modeled a real geometry, then there would be a gap between the blade tip and shroud and there would be tip leakages there. |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 12:23 |
pisoFOAM (LES) - internal pipe flow - convergence | gu1 | OpenFOAM Running, Solving & CFD | 0 | January 11, 2018 16:39 |
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 05:35 |
Discharge of Pressure Vessel into Pipe with Regulator | gajowni2 | System Analysis | 0 | October 31, 2015 18:57 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
