Inlet velocity boundary conditions and pressure-poisson equation |
April 17, 2018, 13:53 |
#21 |
Filippo Maria Denaro
Rep Power: 71 |
This condition generates a du/dx term that must be balanced by the dv/dy in the continuity. You will see a slight deviation of the streamlines, depending on the Reynolds number. This is typical for a spatially developping boundary layer
But I suggested to prescribe the Poiseuille velocity everywhere to see if it is mantained. In such a case no deviation at the corner must appear Last edited by FMDenaro; April 17, 2018 at 16:07. |
April 17, 2018, 14:41 |
Poiseuille flow
#22 |
Selig
Rep Power: 10 |
April 17, 2018, 14:43 |
#23 | |
Rep Power: 71 |
yes a parabolic profile, the constant of the parabola depends on the flow rate... |
April 17, 2018, 15:10 |
Poiseuille flow
#24 |
Selig
Rep Power: 10 |
After testing my solver with a Poiseuille profile my pressure profile still looks incorrect. To me, this points to an issue at the bottom left corner and top left corner BC for pressure, yet I don't see anything incorrect about the way I'm setting the BC.
!Top left corner R(2,ny-1) = (rho/dt)*(inv_dx*(ufs(2,ny-1) - un(1,ny-1)) + inv_dy*(vn(2,ny) - vfs(2,ny-2))) P(2,ny-1) = (1.0-omega)*P(2,ny-1) + omega/(inv_dxx + inv_dyy)*(inv_dxx*P(3,ny-1) + inv_dyy*P(2,ny-2) - R(2,ny-1)) Code:
!Bottom left corner R(2,2) = (rho/dt)*(inv_dx*(ufs(2,2) - un(1,2)) + inv_dy*(vfs(2,2) - vn(2,1))) P(2,2) = (1.0-omega)*P(2,2) + omega/(inv_dxx + inv_dyy)*(inv_dxx*P(3,2) + inv_dyy*P(2,3) - R(2,2)) EDIT 1: At step 550 the velocity profile seems to look better. |
April 17, 2018, 15:34 |
#25 |
Rep Power: 71 |
The solution appears still like the inlet profile you prescribed is not the correct parabolic solution. |
April 18, 2018, 15:21 |
Poiseuille flow
#26 |
Selig
Rep Power: 10 |
Disregard what the 2/3 I wrote. I am doing . With that said I am still getting the two "dots" for pressure. In terms of plotting the profile I am in fact getting a parabolic profile.One screenshot is after 150 time steps and the second image is after 22k time steps, in which it converged to a steady state.
April 18, 2018, 15:33 |
#27 |
Rep Power: 71 |
April 18, 2018, 15:38 |
Poiseuille flow
#28 |
Selig
Rep Power: 10 |
Maybe I am not understanding you, but are you saying I should not be prescribing the profile I gave in the previous post, but rather the analytical solution to the plane Poiseuille problem?
April 18, 2018, 15:41 |
#29 | |
Rep Power: 71 |
yes, you have to check if your code accept the exact solution without changing |
April 19, 2018, 11:58 |
Plane Poiseuille flow
#30 |
Selig
Rep Power: 10 |
April 19, 2018, 12:08 |
#31 |
Rep Power: 71 |
April 19, 2018, 15:18 |
Bug
#32 |
Selig
Rep Power: 10 |
When determining dp/dx I read I should use the difference between the inflow and outflow pressure, is that correct? Otherwise I do not think there is a bug in my BC routine.
April 19, 2018, 15:45 |
#33 |
Rep Power: 71 |
The velocity in a channel of height H for y=(-H/2:+H/2) is
u(y) = -(6Q/H^3)*(y^2-H^2/4) The parameter being Q=u_average*H. If you are using non-dimensional values you can just make non-dimensional the previous law |
April 20, 2018, 12:13 |
Channel flow profile
#34 |
Selig
Rep Power: 10 |
Thank you for bite. It seems like my profile seems to be actually correct. So far, no dots in the vicinity of the inlet appear.
April 20, 2018, 12:21 |
#35 |
Rep Power: 71 |
The last figure seems a correct solution, what about the first one? Is it at the first time step and you set an inviscid initial condition?
April 20, 2018, 12:23 |
Poiseuille flow
#36 |
Selig
Rep Power: 10 |
Sorry I did not caption them . The first one is only after 150 time steps, so its quite immature in the development of the flow.
EDIT: The pressure profiles seem to be consistent from what we would expect given the type of problem. |
April 20, 2018, 12:24 |
#37 | |
Rep Power: 71 |
Have you tried to set the exact profile everywhere as initial condition? The code should not change the initial condition and your pressure solver should converge immediately |
April 20, 2018, 12:35 |
Channel
#38 |
Selig
Rep Power: 10 |
Yes, I have done that and it converges to the fully developed flow within 2-5 iterations.
April 20, 2018, 12:41 |
#39 |
Rep Power: 71 |
Ok, seems to be ok.
April 24, 2018, 13:28 |
3D Situation
#40 |
Selig
Rep Power: 10 |
Returning back to my 3D solver. Here is my situation: If I have no outflow boundary conditions and run a lid driven cavity problem, my code returns the correct solution. As soon as I implement outflow boundary conditions (even a 1 x 1 x sized domain with 32^3 points) my pressure solver diverges. Interesting thing I've noticed is if I remove the advection term, my pressure solver does not diverge. Since I had validated my advection scheme on the LDC, I do not believe my discretization is wrong. I think the criminal is my pressure solver. There are only 5 pressure BCs with outflows conditions. The the outlet in x at the normal and the 4 corner pressure BCs at the outlet.
Example: I prescribe this at as well. Mathematically, I believe the outlet BC is causing continuity at the faces to be violated, thus causing my PPE to diverge. Though the role of advection in causing this is currently confusing me. This divergence of pressure happens at around 480 SOR iterations. I am also using a plug inlet. |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
