How to ineterpret Pressure drop from CFD Results? |
April 14, 2018, 21:27 |
Dave
Rep Power: 8 |
I have a compressible fluid passing through an inlet to two outlets 1 and 2 in Manifold. I was trying to find fluid flow distributions at two outlets and as well as Pressure drop. However, I am not sure how to interpret Pressure drop values from Total Pressure Results of Inlet and Outlets? For example: Total Pressure value at Inlet - 48.3 Pa Outlet 1 - 39.5 Pa Outlet 2 - 36.3 Pa Should I subtract Pressure values of Outlet 1 and 2 from Inlet? Will that give me Pressure drop? Or should I just subtract Outlet 1 from Outlet 2? Your response will be highly appreciated! Thanks |
April 14, 2018, 21:42 |
Dave
Rep Power: 8 |
Here is the results of Fluid distribution and Total Pressure.
Trying to understand how to read Pressure drop values from this. |
April 15, 2018, 02:30 |
Uwe Pilz
Rep Power: 15 |
Yes, of course. That is the pressure necessary for driving the flow.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
April 15, 2018, 02:44 |
#4 | |
Dave
Rep Power: 8 |
Meaning - Inlet 48 Pascal and Outlets 39.5+36.3 Pascals = 75.8 So, total pressure drop = 48 - 75.8 = -27.8 Pascal This is where I am confused. Pressure drop value is in negative? Does it make sense? Thanks! |
April 15, 2018, 06:19 |
Uwe Pilz
Rep Power: 15 |
Not this way.
You have a pressure difference of 48-39.5 = 9.5 Pa for driving the flow from inlet to outlet2 and another pressure difference of 48-36.3=11.7 Pa for outlet2.
April 15, 2018, 07:30 |
Dave
Rep Power: 8 |
Fluent cyclone pressure drop | mkal | FLUENT | 1 | February 20, 2020 00:55 |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 14:42 |
a problem in calculating pressure drop in Fluent? | yu chun | FLUENT | 1 | May 18, 2004 03:40 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
