May 12, 2018, 13:57 |
#41 | |
Filippo Maria Denaro
Rep Power: 71 |
do not forget that you have a system of equations therefore you have to satisfy continuity and momentum equation simultaneously |
May 13, 2018, 04:29 |
#42 |
E
Rep Power: 8 |
Thank you FMDenaro.
What is the checking condition for the momentum? |
May 13, 2018, 04:42 |
#43 |
Rep Power: 71 |
The residuals of the two momentum equations
May 13, 2018, 04:46 |
#44 |
E
Rep Power: 8 |
Do you mean the absolute change in u,v from one itetation to the next one?
May 13, 2018, 04:47 |
#45 |
Rep Power: 71 |
May 13, 2018, 04:53 |
#46 |
E
Rep Power: 8 |
Thank you.
The check has to be done in the provisional velocities or to the corrected in SIMPLE? |
May 13, 2018, 05:38 |
#47 |
E
Rep Power: 8 |
Something else.
Do I have to use periodic boundary conditions mandatorily? |
May 13, 2018, 05:59 |
#48 |
Rep Power: 71 |
May 13, 2018, 06:17 |
#49 |
E
Rep Power: 8 |
Can I avoid them with other way?
May 13, 2018, 06:25 |
#50 |
Rep Power: 71 |
The theoretical solution requires two plates estending infinitely in both directions. Using fictious inlet/outlet BC.s requires that you prescribe the exact solution at inflow and a developed condition at outlet. I never tried such BC.s but I suppose they will drive to the exact solution at the steady state. |
May 13, 2018, 07:02 |
#51 |
E
Rep Power: 8 |
So at the inflow and outflow I can give linear distribution of u and p=0 at both ends. Is it right?
May 13, 2018, 13:09 |
#52 |
E
Rep Power: 8 |
Thank you FMDenaro,
How can I implement periodic boundary conditions in this problem? Can you suggest me a book to study? |
May 14, 2018, 04:02 |
#53 |
E
Rep Power: 8 |
Thank you FMDenaro,
Because I have not dealt with periodic boundary conditions before can you suggest me a book to study about this matter? |
May 14, 2018, 04:20 |
#54 | |
Rep Power: 71 |
You cannot find a complete book about the periodic boundary conditions... it is a numerical issue that is simply implemented in a code by using a link between boundary nodes. I give you an example in 1D for a periodicity over a lenght L. You define the nodes 1,2...N in such a way that x(i)=(i-1)*h+Xs. This way x(N)=Xs+L. Now, you have that nodes 1 and N are linked by periodicity. You compute the equation either in node 1 or N and prescribe the computed value at the node you do not compute. |
May 14, 2018, 06:35 |
#55 |
E
Rep Power: 8 |
Thank you,
Let me ask you: What is Xs? Do I have to alter all the momentum and pressure equations in SIMPLE at two ends or only the u,v,p at these ends? |
May 14, 2018, 06:39 |
#56 | |
Rep Power: 71 |
Xs is only the general value of the position of the left point, it could be also 0. The periodicity involves all the variables. |
May 14, 2018, 06:41 |
#57 |
E
Rep Power: 8 |
I cann't understand if I write x(N)=Xs+L with Xs=0 so X(N)=L, how the code will understand that the start and finish node are the same?
May 14, 2018, 06:47 |
#58 |
Rep Power: 71 |
May 14, 2018, 06:53 |
#59 |
E
Rep Power: 8 |
So all the loops will not calculate anything at the i=N and set the calculated values at i=1 to i=N. Is it right this?
Thank you |
May 14, 2018, 06:58 |
#60 |
Rep Power: 71 |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
FLuent simulation of taylor couette flow of concentric cylinder geometry. | rshbhb | FLUENT | 53 | November 5, 2014 19:07 |
Couette flow in fluent | dreamz | Main CFD Forum | 19 | July 18, 2014 11:13 |
Verification: Couette Flow | AndrewLBloxom | STAR-CCM+ | 0 | March 28, 2014 09:58 |
2D Couette/ Poisuelle Flow | CFD Guy | FLUENT | 1 | April 30, 2011 09:48 |
