April 14, 2000, 08:27 |
Force on cylinders through momentum balance
Hello
I'm developing a CFD 2D finite element method code in my PhD thesis. I'm interested in vortex shedding vibrations of cylinders. In this way I want to calculate forces acting over the cylinder. Besides the conventional integration of tensions due to pressure and velocities over the cylinder wall, I'm also using the balance of momentum approach. This approach is convenient because the matrices are already assembled and it avoids errors in the integration of the cylinder wall. But I'm having some problems. I assembled the matrix equations in order to attain the forces in x and y directions as a nodal quantity. The LHS is composed of a vector of nodal force components times a mass matrix integrated over the Dirichlet boundaries of the problem.(See page 860 of the book of P. Gresho) My questions are: 1) After obtaining the nodal force components how can I get the total force acting over the body? 2) If I have two bodies in the problem, can I use this method to obtain forces in each body ? Can I generate the mass matrix for each body or I have to integrate this mass matrix over all Dirichlet boundaries that are present in the problem? Thanks, Mauro |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Computing wall shear stress with a momentum flux balance | Pomme-Poire | OpenFOAM Post-Processing | 0 | October 5, 2010 17:39 |
how to add a force in the momentum equation | guillaumem | OpenFOAM | 0 | June 14, 2010 03:49 |
Derivation of Momentum Equation in Integral Form | Demonwolf | Main CFD Forum | 2 | October 29, 2009 19:53 |
Modelling a force as a momentum source term - HELP | Rick | FLUENT | 0 | March 9, 2006 10:28 |
