June 26, 2018, 15:03 |
meshing a golf ball
kish
Rep Power: 7 |
In meshing a 2d golf ball I can't use both refinement and inflation in one mesh.
If I use refinement of 3rd level, I am getting a converged solution with less drag.but in controverse I use inflation the iteration goes on, and the drag sees to raise tremendously. kindly help me. |
June 28, 2018, 09:55 |
Joern Beilke
Rep Power: 20 |
There is no way to represent a sphere in 2d. Or do you think that a cylinder is more or less the same as a sphere?
June 28, 2018, 14:22 |
kish
Rep Power: 7 |
yeah, I guess 2d model requires less time and it is a major cross-section of the sphere.
July 1, 2018, 16:14 |
Joern Beilke
Rep Power: 20 |
At least you are not alone with this misconception. There is a whole nation using a cylinder like object and calls it football.
July 1, 2018, 20:20 |
#5 | |
Arjun
Rep Power: 34 |
As someone who has worked 8 years with golf ball simulations, here is my advice. 1. It is extremely 3d simulation. 2. The best solutions with traditional solver were obtained with kinetic Energy based LES model. 3. We ended up our own LES DNS code for it. Here is a hint from one of the simulation university did for us as part of joint work. https://www.youtube.com/watch?v=LvVuuaqCC7A&t=4s Good luck. |
July 5, 2018, 13:15 |
kish
Rep Power: 7 |
Ok, I am doing with 3d, but I have a problem with hard points as it is not supported in 3d inflation then how to have a perfect meshing.
July 5, 2018, 13:31 |
Filippo Maria Denaro
Rep Power: 71 |
July 5, 2018, 13:49 |
Joern Beilke
Rep Power: 20 |
You might have a look into GridPro , when you are seriously interested in this topic.
Airfoil wake capturing http://blog.gridpro.com/the-art-and-...hing-airfoils/ There is also a nice article here: https://community.plm.automation.sie...ck/ba-p/504353 |
July 6, 2018, 12:56 |
#9 |
kish
Rep Power: 7 |
Mesh only a part of the sphere and then replicate to cover all the geometry. Bro how can I do that.
July 6, 2018, 12:59 |
#10 |
kish
Rep Power: 7 |
I can't do a fine meshing with inflation around the dimples of the golf ball.
July 6, 2018, 13:17 |
#11 |
kish
Rep Power: 7 |
Thanks, bro please tell the mesh controls used to have a perfect mesh around a golf ball.
July 6, 2018, 13:36 |
#12 |
Joern Beilke
Rep Power: 20 |
You should probably tell us, which software you are using :-)
July 6, 2018, 13:38 |
#13 |
kish
Rep Power: 7 |
Ansys 15.0
July 6, 2018, 13:54 |
#14 |
Joern Beilke
Rep Power: 20 |
July 16, 2018, 12:32 |
#15 |
kish
Rep Power: 7 |
Please tell me, how to have a perfect 3d mesh over a golf ball in Ansys 15.0 for good results. My lap has 8gb ram.please guide me.
[snappyHexMesh] snappyHexMesh - 3D Wing Meshing Setup & Trials | denbjornen | OpenFOAM Meshing & Mesh Conversion | 1 | May 25, 2020 11:14 |
Structured Mesh on Golf Ball dimples | Qkarl | Mesh Generation & Pre-Processing | 4 | February 22, 2018 08:15 |
Golf ball dimples simulation | Tom12345 | CFX | 11 | November 12, 2017 17:09 |
CFD in sports | David Howell | Main CFD Forum | 21 | July 12, 1999 06:31 |
