test cases for turbulent passive scalar transport
Old   June 27, 2018, 15:23
Default test cases for turbulent passive scalar transport
Anonymous
backscatter is on a distinguished road
Hi all,
I am working on the validation of a turbulence model for passive scalar transport. Apart from the basic cases as fully developed channel flow with heated walls, ht in turbulent boundary layers, passive scalar transport in urban canopies/ cubical obstacles etc, what could be some interesting cases to look at?
Any help is highly appreciated.
Thanks,
backscatter is offline   Reply With Quote
Old   June 27, 2018, 16:29
Cees Haringa
CeesH is on a distinguished road
Stirred tanks? There's a bunch of literature out there, e.g. Coroneo et al. 2011, Jahoda et al. 2007, Kukukova et al. 2005 that provide experimental and CFD data for mixing in turbulent, single phase stirred tanks. For solely experimental, there's a lot more, and if you want to complicate things further, add aeration. The drawback of the cases is that tracer dispersion is typically not locally measured. There are a few studies that add multiple probes (Yeoh et al if I'm correct, and Coroneo uses a 2D-PLIF method), but the full data may be hard to acquire.
CeesH is offline   Reply With Quote
Validation of passive scalar transport kostnermo OpenFOAM Verification & Validation 3 December 18, 2016 15:25
[Solved] Passive Scalar Source Term "Bug" taalf OpenFOAM Running, Solving & CFD 1 July 13, 2016 08:29
using a Fortran library of thermodynamics inside sutherland transport model Mehdi3031 OpenFOAM Programming & Development 0 April 7, 2016 09:34
Issue symmetryPlane 2.5d extruded airfoil simulation 281419 OpenFOAM Running, Solving & CFD 5 November 28, 2015 13:09
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
