How to run SU2 on HPC cluster in parallel on HPC cluster? |
July 13, 2018, 00:44 |
Samir Shaikh
Rep Power: 7 |
Hi All,
I installed SU2 code on CentOS 7 without any error reported and passes all tests provided with source code. When I'm running it on login node using parallel_computation.py script everything works fine, but running same script on compute node hangs execution without termination/error. On compute node it is only using single core of a node. I am using SLURM for job schedulling. I observed that whenever I'm running same script by establishing SSH connection to compute everything works fine. Any input on this will be appreciated |
su2, su2 ad openmpi gcc, su2 bug, su2 error |
[Salome] Salome import "Cannot find file "points" in directory..." | mismichael | OpenFOAM Meshing & Mesh Conversion | 5 | June 22, 2019 02:56 |
Problem with foam-extend 4.0 ggi parallel run | Metikurke | OpenFOAM Running, Solving & CFD | 1 | December 6, 2018 15:51 |
Problem in foam-extend 4.0 ggi parallel run | Metikurke | OpenFOAM Running, Solving & CFD | 0 | February 20, 2018 06:34 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Scaling for parallel run for SU2 | nileshjrane | SU2 | 1 | January 1, 2015 20:06 |
