Inlet Mixing at 1D Numerical Model | Stratified Storage |
July 24, 2018, 09:05 |
Khan
Rep Power: 7 |
Thank you in advance,
I could manage to build a numeric model for a sensible stratified storage tank by means of solving the convection-diffusion equation (1D) by use of Crank-Nicolson scheme. I try to implement a mixing effect that is changing in a hyperbolic decaying form from the top of the tank (inlet is here) to the bottom. In the above equation, eps_eff is this mixing effect. The details can be found here: Zurigat et al - Stratified thermal storage tank inlet mixing characterization. Please see the Case 0, 1, and 2 under the section %% Inlet Mixing in the Matlab code given below. For Case 1 - No mixing effect included so a constant thermal diffusivity through the tank height, here is the result (simulation results are solid lines compared with the experimental result shown with circles): When Case 0 is active, the thermal diffusivity is replaced from constant to a decaying form through the tank height via multiplication with eps_eff in the code, the results become weird: If Case 2, the thermal diffusivity is magnified up to a level up at a constant rate at all tank levels, the temperature does not increase above the inlet temperature but Case 0 all the time results in abnormal temperature increase. Would you please check my codes and/or explain to me why this abnormal temperature increase happens (stability, oscillation,... issues?)? Shall I try upwind or any other scheme in my solution considering the inlet mixing effect? Or any other suggestions? Here is the Matlab code: Code:
function [T,dh,dt] = CDR_CrankNicolson_Exp_InletMixing(t_final,n) %% 1D Convection-Diffusion-Reaction (CDR) equation - Crank-Nicolson scheme % solves a d2u/dx2 + b du/dx + c u = du/dt %% References % pg. 28 - http://www.ehu.eus/aitor/irakas/fin/apuntes/pde.pdf % pg. 03 - https://www.sfu.ca/~rjones/bus864/notes/notes2.pdf % http://nptel.ac.in/courses/111107063/24 tStart = tic; % Measuring computational time %% INPUT % t_final : overall simulation time [s] % n : Node number [-] %% Tank Dimensions h_tank=1; % [m] Tank height d_tank=0.58; % [m] Tank diameter vFR=11.75; % [l/min] Volumetric Flow Rate v=((vFR*0.001)/60)/((pi*d_tank^2)/4); % [m/s] Water velocity dh=h_tank/n; % [m] mesh size dt=1; % [s] time step maxk=round(t_final/dt,0); % Number of time steps % Constant CDR coefficients | a d2u/dx2 + b du/dx + c u = du/dt a_const=0.15e-6; % [m2/s]Thermal diffusivity b=-v; % Water velocity c=0; %!!! Coefficient for heat loss calculation %% Inlet Mixing - Decreasing hyperbolic function through tank height eps_in=2; % Inlet mixing magnification on diffusion A_hyp=(eps_in-1)/(1-1/n); B_hyp=eps_in-A_hyp; Nsl=1:1:n; eps_eff=A_hyp./Nsl+B_hyp; a=a_const.*eps_eff; % Case 0 % a=ones(n,1)*a_const; % Case 1 % a=ones(n,1)*a_const*20; % Case 2 %% Initial condition - Tank water at 20 degC T=zeros(n,maxk); T(:,1)=20; %% Boundary Condition - Inlet temperature at 60 degC T(1,:)=60; %% Formation of Tridiagonal Matrices % Tridiagonal Matrix @Left-hand side subL(1:n-1)=-(2*dt*a(1:n-1)-dt*dh*b); % Sub diagonal - Coefficient of u_i-1,n+1 maiL(1:n-0)=4*dh^2+4*dt*a-2*dh^2*dt*c; % Main diagonal - Coefficient of u_i,n+1 supL(1:n-1)=-(2*dt*a(1:n-1)+dt*dh*b); % Super diagonal - Coefficient of u_i+1,n+1 tdmL=diag(maiL,0)+diag(subL,-1)+diag(supL,1); % Tridiagonal Matrix @Right-hand side subR(1:n-1)=2*dt*a(1:n-1)-dt*dh*b; % Sub diagonal - Coefficient of u_i-1,n maiR(1:n-0)=4*dh^2-4*dt*a-2*dh^2*dt*c; % Main diagonal - Coefficient of u_i,n supR(1:n-1)=2*dt*a(1:n-1)+dt*dh*b; % Super diagonal - Coefficient of u_i+1,n tdmR=diag(maiR,0)+diag(subR,-1)+diag(supR,1); %% Boundary Condition - Matrices tdmL(1,1)=1; tdmL(1,2)=0; tdmL(end,end-1)=0; tdmL(end,end)=1; tdmR(1,1)=1; tdmR(1,2)=0; tdmR(end,end-1)=1; tdmR(end,end)=0; MMtr=tdmL\tdmR; %% Solution - System of Equations for j=2:maxk % Time Loop Tpre=T(:,j-1); T(:,j)=MMtr*Tpre; if T(end,j)>=89.9 T(:,j+1:end)=[]; finishedat=j*dt; ChargingTime=sprintf('Charging time is %f [s]', finishedat) tElapsed = toc(tStart); SimulationTime=sprintf('Simulation time is %f [s]',tElapsed) return end end end |
July 24, 2018, 20:51 |
Arjun
Rep Power: 34 |
Based on the graphs, your diffusion term is creating a source that should not be there. If i were you i will just set the diffusion term to 0 in the cell connected to boundary and run it.
July 25, 2018, 03:31 |
Filippo Maria Denaro
Rep Power: 71 |
I see a poor accordance also in the constant thermal diffusivity case...
However, I haven't see the code but if you manage the eps_eff in the Crank-Nicolson scheme have you correctly considered the effect in the time-variying case? The matrix will change at each time step. Then, how do you discretize the spatial derivatives? |
July 25, 2018, 03:35 |
Khan
Rep Power: 7 |
Thank you arjun for your quick reply. I tried your suggestion but didn't work. Again I have this abnormal temperature increase.
July 25, 2018, 03:45 |
#5 | |
Khan
Rep Power: 7 |
Coefficients of approximated temperatures in the Crank-Nicolson scheme applied stay same with time so I calculate it once at the beginning (a fixed matrix). Do you think the problem is this? |
July 25, 2018, 03:56 |
#6 | |
Rep Power: 71 |
Therefore the coefficients of the matrix are time-dependent not constant |
July 25, 2018, 04:11 |
Khan
Rep Power: 7 |
The coefficients are dependent on the tank height but all are constant through time.
July 25, 2018, 04:40 |
#8 | |
Rep Power: 71 |
But are you including in the CN integration also the convection part?? Have you checked that a purely explicit FTCS works fine? Increasing the eps_eff greater to 1 you should see exactly the opposite effect, check also the correct sign in the coefficients, what you het is a sort of anti-diffusion. |
July 25, 2018, 05:12 |
#9 | ||
Khan
Rep Power: 7 |
No. What will you recommend of? I am new in this finite difference approximation methods (my understanding in their superiority -i.e. accuracy, stableness, etc. is missing)! Which scheme shall I use? If possible, any source can be rewarding in my solution. Quote:
Thank you. |
July 25, 2018, 05:23 |
#10 |
Rep Power: 71 |
As you are not experienced, start solving the explicit first order integration in time. Use central second order formula for the space derivatives.
At high values of eps_eff the numerical stability constraint is mainly based on dt*diff_coef/h^2<0.5 For convection dominated case you need a fine grid to avoid numerical oscillations |
July 25, 2018, 05:27 |
#11 | |
Khan
Rep Power: 7 |
July 25, 2018, 08:35 |
#12 | |
Khan
Rep Power: 7 |
July 25, 2018, 10:03 |
#13 | |
Rep Power: 71 |
July 26, 2018, 03:18 |
#14 | |
Khan
Rep Power: 7 |
The boundary condition at the right/bottom is dT/dt=0. |
July 26, 2018, 03:28 |
#15 |
Rep Power: 71 |
Therefore, if I am right this problem has a thermal coefficient that increases going to the right of the diagram.
Just as a test, could you use the same law for eps_eff but changing only the sign so to decrease it? |
July 26, 2018, 04:48 |
#16 | |
Khan
Rep Power: 7 |
July 26, 2018, 05:07 |
#17 |
Rep Power: 71 |
The case now shows a diminishing temperature, right? So, it seems that the numerical solution describes opposite physical behaviors.
July 26, 2018, 08:20 |
#18 |
Khan
Rep Power: 7 |
Weirdly the hyperbolic decaying form of eps_eff cause this issue, either in the original case or in this reverse direction case (the last having issue on the right boundary). When I multiply a constant of eps_eff with all elements of the thermal diffusivity, alpha, the results are not obtained with this abnormal temperature increase but a high rate of diffusion as expected.
July 26, 2018, 11:56 |
#19 | |
Rep Power: 71 |
Could you post your Matlab code for the simple FTCS case? I want try to have a check |
July 27, 2018, 03:44 |
#20 |
Khan
Rep Power: 7 |
The udf.h headers are unable to open- in VISUAL STUDIO 13 | sanjeetlimbu | Fluent UDF and Scheme Programming | 4 | May 2, 2016 05:38 |
CFX Simple valve model, inlet and outlet conditions | 749604 | CFX | 24 | August 11, 2014 18:51 |
convergence problem of the SST and RNG k-e model for mixing tank | ziyan7 | FLUENT | 0 | March 8, 2011 06:13 |
How to model a rack of the inlet? | silvia_petkova | Main CFD Forum | 0 | March 17, 2010 06:08 |
