[Sponsors] | |||||
Inlet Mixing at 1D Numerical Model | Stratified Storage |
#21 |
Filippo Maria Denaro
Rep Power: 75 ![]() ![]() ![]() |
#22 |
Khan
Rep Power: 9 ![]() |
Still I encounter the same problem (abnormal temperature increase) when I include the unsteady thermal diffusivity in the second order derivative.
Here is the Matlab code for the Forward Time Central Space (FTCS) for ![]() Code:
function [T] = CDR_FTCS_InletMixing(t_final,n)
%% 1D Convection-Diffusion-Reaction (CDR) equation - (Forward-Time Central-Space)
% solves a d2u/dx2 + b du/dx + c u = du/dt
%% References
% pg. 03 - https://www.sfu.ca/~rjones/bus864/notes/notes2.pdf
% Azad et al - Stability analaysis of finite difference schemes for an advection diffusion equation
tStart = tic;
%% INPUT
%n [-] Number of nodes
%t_final : Total time period for simulation [s]
% Tank Dimensions
height=1.05; % [m] Tank height
v=5.2397e-4; % [m/s] Water velocity
dx=height/n; % [m] mesh size
dt=0.05; % [s] time step
maxk=round(t_final/dt,0); % Number of time steps
NumParam=sprintf('The step size is %f and the time step is %f',dx, dt)
% Constant CDR coefficients | a d2u/dx2 + b du/dx + c u = du/dt
a_const=0.15e-6; % [m2/s]Thermal diffusivity
b=-v; % Water velocity
c=0; %!!! Coefficient for heat loss calculation
st1=2*a_const*dt/(dx^2)
st2=v*dt/(2*dx)
%% Inlet Mixing - Decreasing hyperbolic function through tank height
eps_in=20; % Inlet mixing magnification on diffusion
A_hyp=(eps_in-1)/(1-1/n);
B_hyp=eps_in-A_hyp;
Nsl=1:1:n;
eps_eff=A_hyp./Nsl+B_hyp;
a=a_const.*eps_eff; % Case 0
% a=ones(n,1)*a_const; % Case 1
% a=ones(n,1)*a_const*500; % Case 2
%% Initial condition - Tank water at 40 ?C
T=zeros(n,maxk);
T(:,1)=40;
%% Boundary Condition
T(1,:)=90;
%% Tridiagonal Matrix @Right-hand side
subR(1:n-1)=dt*a(1:n-1)/(dx^2)-b*dt/(2*dx); % Sub diagonal - Coefficient of u_i-1,n
maiR(1:n-0)=1-2*a*dt/(dx^2); % Main diagonal - Coefficient of u_i,n
supR(1:n-1)=a(1:n-1)*dt/(dx^2)+b*dt/(2*dx); % Super diagonal - Coefficient of u_i+1,n
tdmR=diag(maiR,0)+diag(subR,-1)+diag(supR,1);
%% Boundary Condition - Matrices
tdmR(1,1)=1; tdmR(1,2)=0;
tdmR(end,end-1)=0; tdmR(end,end)=1;
for j=2:maxk % Time Loop
Tpre=T(:,j-1);
T(:,j)=tdmR*Tpre;
if T(end-1,j)>=89.9
T(:,j+1:end)=[];
finishedat=j*dt;
ChargingTime=sprintf('Charging time is %f [s]', finishedat)
tElapsed = toc(tStart);
SimulationTime=sprintf('Simulation time is %f [s]',tElapsed)
return
end
end
end
![]() Code:
function [T] = CDR_FTCS_InletMixing_Last(t_final,n)
tStart = tic;
%% INPUT
% Tank Dimensions
dt=0.005; % [s] time step
st2=v*dt/(2*dx)
eps_in=5; % Inlet mixing magnification on diffusion
B_hyp=eps_in-A_hyp;
Nsl=1:1:n;
a(:,1)=a_const.*eps_eff; % Case 0
T=zeros(n,maxk);
T(:,1)=40;
T(1,:)=90;
sub_subR(1:n-2)=dt/(4*dx^2);
mai_subR(1:n-1)=dt/(dx^2);
sup_subR(1:n-2)=-dt/(4*dx^2);
tdm_subR=diag(mai_subR,0)+diag(sub_subR,-1)+diag(sup_subR,1);
subR(1:n-1)=tdm_subR*a(1:n-1)-b*dt/(2*dx);
maiR(1:n)=1-2*a*dt/(dx^2);
sub_supR(1:n-2)=-dt/(4*dx^2);
mai_supR(1:n-1)=dt/(dx^2);
sup_supR(1:n-2)=dt/(4*dx^2);
tdm_supR=diag(mai_supR,0)+diag(sub_supR,-1)+diag(sup_supR,1);
supR(1:n-1)=tdm_supR*a(1:n-1)+b*dt/(2*dx);
tdmR(end,end-1)=0; tdmR(end,end)=1; %%% Something WRONG!!!!!
Tpre=T(:,j-1);
T(:,j)=tdmR*Tpre;
if T(end-1,j)>=89.9
T(:,j+1:end)=[];
finishedat=j*dt;
return
end
end
end
#23 |
That is written as a function not as a full program? I cannot run without the parameter at line 20
#24 | |
Khan
Here is the plotter script (not a function this time) but please make sure that function output is Tlast (this plot script based on Tlast variable name!). Code:
Tlast = Tlast(:,any(Tlast,1)); n=length(Tlast(:,1)); h=1:n-1; h=(1.05/n)*h';
slmin=1; slmax=size(Tlast,2); hold on;
plot(h,Tlast(2:end,1)); axis([0 1.2 20 120]);
hsl = uicontrol('Style','slider','Min',slmin,'Max',slmax,...
'SliderStep',[1 1]./(slmax-slmin),'Value',1,...
'Position',[5 5 200 20]);
set(hsl,'Callback',@(hObject,eventdata) plot(h,Tlast(2:end,round(get(hObject,'Value')))) )
#25 |
I wrote few line in "educational" style, check it. I see reasonable results.
clear, format long e % Tank Dimensions height=1.05; % [m] Tank height v=5.2397e-4; % [m/s] Water velocity n=1000 dx=height/n; % [m] mesh size dt=0.1; % [s] time step n_time_limit=1000 a_const=0.15e-6; % [m2/s]Thermal diffusivity x(1:n+1)=dx*(1:n+1)-dx; %% Inlet Mixing - Decreasing hyperbolic function through tank height eps_in=20; % Inlet mixing magnification on diffusion A_hyp=(eps_in-1)/(1-1/n); B_hyp=eps_in-A_hyp; Nsl=1:1:n+1; eps_eff=A_hyp./Nsl+B_hyp; coeff=a_const.*eps_eff; % Case 0 plot(x,coeff) pause stab=coeff.*dt/dx/dx; plot(x,stab) pause Told(2:n)=40; Told(n+1)=Told(n); Told(1)=90; n_time_limit=10000; for k=1:n_time_limit for i=2:n Tnew(i)=Told(i)-v*dt*(Told(i+1)-Told(i-1))/(2*dx)+dt*coeff(i)*(Told(i+1)-2*Told(i)+Told(i-1))/(dx*dx); end Told(2:n)=Tnew(2:n); Told(n+1)=Tnew(n); k plot(x,Told) pause end |
#26 |
Khan
Thank you Filippo. I could the reach the same reasonable result by basing on the for loop use as yours to calculate the new temperatures. I guess that the tridiagonal matrix formed in my previous codes are misleading. Thanks again.
#27 |
Ok, Good!
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| The udf.h headers are unable to open- in VISUAL STUDIO 13 | sanjeetlimbu | Fluent UDF and Scheme Programming | 4 | May 2, 2016 06:38 |
| CFX Simple valve model, inlet and outlet conditions | 749604 | CFX | 24 | August 11, 2014 19:51 |
| Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
| convergence problem of the SST and RNG k-e model for mixing tank | ziyan7 | FLUENT | 0 | March 8, 2011 07:13 |
| How to model a rack of the inlet? | silvia_petkova | Main CFD Forum | 0 | March 17, 2010 07:08 |
