Stagnation Conditions in the Tds Equations
Old   November 29, 2023, 12:53
Default Stagnation Conditions in the Tds Equations
David Scott is on a distinguished road
Is there a proof for why the stagnation conditions (T_0 and P_0) may be used in the Tds equations?
\Delta S = c_P \ln \left( \frac{T_2}{T_1} \right) - R \ln \left( \frac{P_2}{P_1} \right)
Denton 1993 states "the temperatures, pressures, and densities used in the Tds equations may be either all static values or all stagnation values because by definition the change from static to stagnation conditions is isentropic."
Further, some sources justify this with "the Tds equations apply between any two thermodynamic end states". Are stagnation temperature and stagnation pressure thermodynamic state variables?
David Scott is offline   Reply With Quote
Old   November 29, 2023, 13:27
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
This is a jump relation for the entropy in the normal shock wave, being adiabatic the stagnation temperature is constant but not the stagnation pressure.
The states are determined indipendently from the path.
FMDenaro is offline   Reply With Quote
Old   November 29, 2023, 14:25
The Tds equations follow from the first and second laws of thermodynamics. They are applicable to many flows other than the case of a normal shock. My interest happens to be understanding losses in turbomachines.
Specifically, I'm seeking a derivation for,
\Delta S = c_P \ln \left( \frac{T_{0_{2}}}{T_{0_{1}}} \right) - R \ln \left( \frac{P_{0_{2}}}{P_{0_{1}}} \right)
Old   November 29, 2023, 14:47
Yes, in general you start from Gibbs relation to integrate between the state 1 and 2.
Old   November 29, 2023, 18:45
Lucky
The key assumption is that the the process going from the static to stagnation conditions is via an isentropic process.
The entropy change from 1 to 01 is 0 because the change from static-to-stagnation conditions is (assumed to be) isentropic. The change from 2 to 02 is also 0. Hence the change from 1 to 2 is equal to the change from 10 to 20. Recall also that for a simple system, the thermodynamic state is fully characterized by two intensive properties (static temperature and static pressure). The stagnation conditions at state 1 or 2 are fully specified by knowing their static conditions and vice versa, hence the entropy change between 1 and 2 or 01 and 02 must be equal or you do not have a thermodynamic system.
It is common in engineering applications to assume that the change from static to a (hypothetical) stagnation conditions is isentropic. This condition is explicitly noted in your quote of Denton. The usage of stagnation properties for performance calculations in turbomachinery is also consistent with this assumption.
Fortran - Lid-Driven Cavity Boundary Conditions Error when using SIMPLE method BaklavaBaby29 Main CFD Forum 8 January 23, 2023 17:22
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Periodic boundary conditions for compressible Euler equations selig5576 Main CFD Forum 24 April 25, 2017 16:43
Exit Boundary Conditions N-S equations lavan Main CFD Forum 2 July 2, 2005 03:10
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 18:29
