May 2, 2000, 09:23 |
Tip Clearance in Transonic Compressors
Hi everybody,
I am a PH.D student and I am going to start my thesis which is about studing flow field in the tip clearance of a transonic compressor. I would be so grateful if you tell me how I can start and if you introduce me some helpful references . sincerely yours, Behnam.H.Beheshti Sharif University of Technology |
May 2, 2000, 10:16 |
Re: Tip Clearance in Transonic Compressors
(1). Try to read the ASME/ Journal of Turbomachinery. And ASME turbomachinery conference papers.
May 2, 2000, 15:56 |
try Budugur lakshminarayana's book on turbomachinery "fluid dynamics and heat transfer of turbomachinery" it's a good reference on anything to do with turbomachines. john also pointed you to some good reference journals. increasing papers are available online either in collections or at the authors homepage eg http://web.mit.edu/aeroastro/www/labs/GTL/ is mit's gas turbine lab homepage
May 3, 2000, 03:37 |
Look for the book: Compressor Aerodynamics by. N. A. Cumpsty. There are also a lot of references.
September 16, 2010, 16:16 |
question
N.Re.
I read the Nasa report "Laser Anemometer Measurements in a Transonic Axial Flow Fan Rotor" that is about NASA rotor 67 and it has a lot of data about the 3D geometry about this blade,and I tried to produce the 3D geometry of this blade that I need it immediately but I couldn't. Does any body have the 3D geometry of this blade in IGES or STEP format?
Thanks Last edited by annie; September 19, 2010 at 11:32. |
September 18, 2010, 01:52 |
#7 | |
N.Re.
Thanks Last edited by annie; September 19, 2010 at 11:34. |
May 20, 2013, 21:47 |
#8 | |
Liuwei
thank you very much. |
[ICEM] Turbine blade with filleting and tip clearance | Pursuor | ANSYS Meshing & Geometry | 4 | July 7, 2010 13:56 |
Meshing in tip clearance. | me | Siemens | 0 | August 25, 2008 03:20 |
Tip Clearance | Liam | CFX | 3 | September 7, 2005 05:30 |
Tip clearance pressure distribution | Karthik | FLUENT | 1 | August 27, 2004 10:12 |
Tip Clearance | Drona | CFX | 0 | October 17, 2002 05:25 |
