October 17, 2018, 04:49 |
Original publication von Neumann
Filippo Maria Denaro
Rep Power: 71 |
Has anyone knowledge of the first publication of the von Neumann stability analysis and its original paper?
October 17, 2018, 07:34 |
#2 | |
Arjun
Rep Power: 34 |
This is some hint here. http://inis.jinr.ru/sl/Simulation/Hi...994/chap08.pdf if you have title in mind then it might help the search. |
October 17, 2018, 07:43 |
#3 | |
Arjun
Rep Power: 34 |
Sent you both papers this book mentions in the start. I believe this is what is originally available. |
October 17, 2018, 08:13 |
#4 | |
Rep Power: 71 |
Many thanks, I received both I know that Hirsch cited these two papers, I was also wondering if the original classified manuscript has never been published. Thanks again |
October 17, 2018, 09:07 |
#5 | |
Arjun
Rep Power: 34 |
I had no idea until you mentioned it. I just searched both reference and sent to you. I believe that the original report would be in print so only few have access to it. |
October 17, 2018, 09:13 |
#6 | |
Rep Power: 71 |
The reason for my question is to see the original idea of von Neumann. I want to assess that he considered the round-off error (not the discretization error) in the definition and he assumed that such error is a finite dimensional vector that is governed by the same discrete (not the continuous) equation that is solved. There is somehow confusion in literature but I always considered valid the analysis as presented by Hirsch. |
October 17, 2018, 13:47 |
Lucky
Rep Power: 66 |
Not sure if it would be anywhere in the declassified von Neumann papers. Personally I haven't browsed the collection myself.
https://www.loc.gov/item/mm82044180/ My next trip to D.C., I'll take a peek. |
October 17, 2018, 14:51 |
#8 | |
Rep Power: 71 |
I am in touch with an LA senior researcher, he wrote me about the LA-657 report of 1947. |
Von Neumann Stability | mathgra | Main CFD Forum | 1 | July 2, 2018 09:57 |
2D von neumann | soes | CONVERGE | 2 | March 23, 2016 16:56 |
UDF von neumann | nadesan | Fluent UDF and Scheme Programming | 0 | October 15, 2012 07:22 |
Lax method stability via von neumann analysis | morteza08 | Main CFD Forum | 1 | June 5, 2010 12:43 |
wmake compiling Problem with OF1.5 | openTom | OpenFOAM Installation | 4 | May 3, 2009 14:44 |
