More advise on libraries to solve linear system
Old   May 18, 2000, 18:37
Default More advise on libraries to solve linear system
Ricardo Bonon
Hello everybody,
what is the more suitable kind of solvers for linear systems to use with equations from finite element triangular discretizations, sparse iterative solvers or LU/Gauss factorization solvers?
Browsing through netlib, I found LAPACK is by far the most widely used library. Netlib also recommend meschach for C programmers. Both libraries are direct solvers, using LU factorization (if I am not wrong).
When it comes to the iterative solvers, the most cited are BlockSolve, IML++, etc ... and LASPack, the one I've tested without success.
So I ask you: what libraries do you use in your programs? What about it's stability and robustness? And its performance.
I know these are quite general questions, but any answer will help me.
Thank you!
please help me which solver is better for my application Ger_US OpenFOAM 8 January 8, 2013 12:29
Linear System solver in Newton method proto84 Main CFD Forum 3 November 30, 2009 10:06
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
On the block tridiagonal linear system zhanglei Main CFD Forum 0 July 18, 2000 08:55
Good library to solve huge linear system Ricardo Bonon Main CFD Forum 3 May 19, 2000 06:24
