Normalization of the energy spectrum and homogeneous turbulence |
March 15, 2019, 04:40 |
luca mirtanini
Rep Power: 8 |
I have two doubts: 1. I have not understood the scope of the Energy spectrum normalization. The only explanation that I found can be the comparison between more graph in order to align them in the inertial subrange, as done here at page 350 http://storm.colorado.edu/~jweiss/50...avalli1994.pdf 2. Someone can explain me the definition of homogeneous turbulence? I cannot understand why a turbulence can be defined homogeneous since, turbulence is always confined in an area as a wake or a jet. Thank you |
March 15, 2019, 06:03 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
1. Consider that making a variable non-dimensional is simple but does not guarantee that the non-dimensional values are of O(1). Normalization means you use the proper reference variables to get that, 2. there is a standard definition in terms of the property of the statistics, just see a statement on Wikipedia https://en.wikipedia.org/wiki/Homoge...pic_turbulence |
March 15, 2019, 08:19 |
luca mirtanini
Rep Power: 8 |
1. I have asked why they decided to normalise
2. I ve already seen this wikipedia page. My question was: how can this theory work for turbulence which is confined only in particular area. |
March 15, 2019, 08:40 |
Rep Power: 71 |
So you have the answer: if the statistics depend on the translated location, the flow is not homogeneous. This is what happens, for example, when you move along the normal direction to a wall.
March 15, 2019, 10:18 |
luca mirtanini
Rep Power: 8 |
When a flow can be approximated as homogeneous?
March 15, 2019, 10:58 |
Rep Power: 71 |
Anomaly in energy spectrum | arunsmec | Main CFD Forum | 17 | June 3, 2017 07:38 |
Initial conditions in physical space from energy spectrum | arunsmec | Main CFD Forum | 3 | February 19, 2016 15:32 |
Energy spectrum | muta | Main CFD Forum | 0 | August 31, 2006 03:27 |
Help needed on homogeneous isotropic turbulence an | Guoping Xia | Main CFD Forum | 0 | March 12, 2006 21:54 |
isotropic homogeneous turbulence | tingguang | Main CFD Forum | 0 | August 1, 2002 17:08 |
