Multiple surface arrangement
Old   March 16, 2019, 06:57
Default Multiple surface arrangement
FlemmingT is on a distinguished road
Hello community,
I am researching the flow behaviour for two wings in a close together arrangement. That meanīs, the second wing is from an equal size and only 0.3 times the chord length away from the front wing.
I set up a steady state case with SST model and local timescale factor to 4. The Boundary is captured with inflation layers and a refined body-of-influence box used near the wings.
The forces are fully converged after ~600 iterations, but the drag value for the front wing is negative at zero angle of attack. Moving the wings further apart from each other the drag becomes positive along the x-axis, which is defined positive in the direction of the flow. Therefore, a negative drag seems to be unrealistic, false.
Do you have any advice or ideas about how to handle this, maybe applying some local factors, changes in the mesh or separation issues?
Thank you all,
Flemming
FlemmingT is offline   Reply With Quote
interactions, negative drag
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 04:17
How To Create Fowcs William Hawkings Surface in Fluent? marinkobezu FLUENT 7 October 25, 2018 10:51
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 04:31
Multiple surface particle injections from the command line mbeals FLUENT 0 June 3, 2009 14:11
