April 16, 2019, 10:38 |
compressible flow simulation
SAM
Rep Power: 14 |
Dear all
I am currently trying to simulate the combustion of methane-air in an incinerator, where methane is injected through a nozzle and mixed with air. I used to apply low-Mach number approximation for the simulation since the maximum Mach number was around 0.3. I recently got a case that the Mach number is around 2 at the nozzle. However, the rest of the flow is at Mach <0.3. The question is, the low-Mach number is still valid or I have use fully compressible equations. Thank you |
April 16, 2019, 15:49 |
Lucky
Rep Power: 65 |
What software are you using and what equations are being solved?
For non-reacting flows, most commercial CFD software (Fluent, Star-CCM, CFX, mostFOAM) solve the compressible navier-stokes and there is no problem. For reacting flows it's a little more complicated because of the combustion model usually has limitations. |
April 16, 2019, 16:02 |
#3 | |
Filippo Maria Denaro
Rep Power: 71 |
Yes, you must use the compressible flow formulation |
April 17, 2019, 03:09 |
#4 | |
SAM
Rep Power: 14 |
Thank you for your reply. I use fluent and the reacting flow equations are solved.
April 17, 2019, 10:59 |
Lucky
Rep Power: 65 |
Fluent always solves compressible navier-stokes (unless you are using the inviscid flow model). If you use detailed chemistry there is also no issue.
Some of the combustion models have limitations on compressibility effects due to the nature of the models themselves. Since you're unwilling to tell us what model you are using, I'll leave it up to you to figure it out. |
Closed domain compressible flow simulation | Vaaj | FLUENT | 2 | May 7, 2017 19:38 |
Wind Tunnel Flow Simulation Mass Flow BC Issue | ledelman | SU2 | 4 | August 3, 2014 18:38 |
Compressible flow Simulation in CFDesign | krishna_msrit | Autodesk Simulation CFD | 1 | September 9, 2012 23:00 |
how to set BC for compressible flow target mass flow rate | foolboy007 | FLUENT | 1 | April 4, 2012 03:24 |
low speed compressible flow | lily | CFX | 2 | November 16, 2005 05:15 |
