Rep Power: 7 ![]() |
Hi All,
To resolve some non-turbulence small-scale details in high-speed flows, I would like to use a finer resolution. Using DNS or LES would make better sense, but my current code is RANS-based. Is there a general rule or something? |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
There isn't a minimum size for RANS. You can go as small as you like until the fluid particle model is no longer valid (no more continuity or navier-stokes).
Ashwani
Rep Power: 12 ![]() |
If you are using low Reynolds number RANS model, you have to ensure near the wall y+< 1 or 2.
On grid independent solution for pulsatile flow | David | FLUENT | 5 | March 25, 2022 03:33 |
How to confirm mesh element size at turbo grid? | YOUNS | CFX | 2 | April 25, 2018 09:27 |
minimum grid size in gas flow simulation in cylinder | YHY | CONVERGE | 1 | October 30, 2017 06:49 |
Algebraic Model for Variance - grid size surface field | alessio.nz | OpenFOAM | 0 | June 28, 2012 05:03 |
How to determine the grid size in LES | lin | OpenFOAM Running, Solving & CFD | 0 | April 28, 2010 21:55 |
