Parallel plate channel with staggered ribs
Old   May 28, 2019, 16:39
Lightbulb Parallel plate channel with staggered ribs
Edoardo
edoardobrunetto is on a distinguished road
Hi everyone !
I am studying the turbulent flow in a parallel plate channel equipped with staggered ribs. The shape of the ribs is trapezoidal, but front and rear edges are rounded (see attachment).
I kindly ask you if someone could help me with some references that could indicate a correlation to compute Nu number in this particular geometry. All the refereces I've read are about square channel ( and not parallel plates ).
In particular, I've seen in the available Nu correlations for square channels I have to use hydraulic diameter, that for a parallel plate could be computed as 2H. May be a reasonable assumption?
Thank you for your attention
Last edited by edoardobrunetto; May 28, 2019 at 16:59. Reason: adding clarification
edoardobrunetto is offline   Reply With Quote
Old   June 4, 2019, 16:33
Santiago Lopez Castano
Santiago is on a distinguished road
Originally Posted by edoardobrunetto View Post
Hi everyone !
Check a letter published by Foroozani et al. (2019) on Physics E. She has done some work on RBC with grooves.
Santiago is offline   Reply With Quote
Old   June 5, 2019, 03:50
Edoardo
Thank you for your answer Santiago, but it's not the geometry I am looking for
I am still looking for a reference in which someone has did a similar study, in order to validate my results.
nusselt, parallel, plate., ribs, turbulent
Error running simpleFoam in parallel Yuby OpenFOAM Running, Solving & CFD 14 October 7, 2021 04:38
FSI two-way:how to select density and Young modulus for a flexible plate Mansoor_shad FLUENT 1 June 28, 2017 05:44
flow thru parallel plate with solid heat generater cindy FLUENT 1 October 10, 2005 22:54
Parallel Plate Rheometer vs Cone & Plate beginner Main CFD Forum 0 March 19, 2003 11:49
free convection between 2 infinite parallel plate runny craven Main CFD Forum 2 September 19, 2001 05:45
