June 8, 2019, 05:00 |
Stability with Under Relaxation factor
Arijit Saha
Rep Power: 7 |
I was conducting a simulation of two airfoil and the residual monitor at the beginning was showing oscillating behavior. Then I reduced the URF and Explicit relaxation factor too and with successive trial method the residuals got damped. I was doing with k epsilon model and kept the tolerance to be 0.001 for k and epsilon and for x,y velocity and continuity kept 1*10^-6.
All the residuals converged except epsilon. Now my question is which URF value should I change so that the epsilon converge? And when should I change the explicit residual value? Note- In a separate monitor the Cl value is almost horizontal irrespective of the non-convergence of the epsilon value. Will be really helpful if someone replies. |
Suitable range of relaxation factor for VOF boiling cases? | manupp | STAR-CCM+ | 1 | February 4, 2020 06:07 |
Lets talk about relaxation factor optimization | chriss85 | OpenFOAM Running, Solving & CFD | 35 | June 21, 2019 09:54 |
Long output in terminal. | ssa_cfd | OpenFOAM Running, Solving & CFD | 1 | March 18, 2019 05:25 |
What's happening to my solution for lower relaxation factor | casesam | OpenFOAM Running, Solving & CFD | 3 | October 22, 2015 01:25 |
Question on adjusting relaxation factor | CFD Rookie | Main CFD Forum | 3 | January 26, 2004 14:37 |
