transient convergence- PISO/Coupled vs Simplec |
July 3, 2019, 07:56 |
Andrea
Rep Power: 6 |
I am doing a transient simulation with a large time step (0.8s) to compute the flow and turbulence field in a Zn-bath. In the fluent user manual is indicated that the transient simulation should work better with PISO or Coupled (for larger time steps). However when I use PISO or Coupled the maximum Velocity in the bath increases very much and the mean velocity varies also quite a lot in comparison with the Simplec scheme. I also use very low under-relaxation factors of 0.05 for flow and turbulence to get a stable solution. Does anyone have experience with different schemes for the transient simulation with large time steps? Thank you |
July 3, 2019, 11:27 |
Lucky
Rep Power: 66 |
PISO does not like large time steps. COUPLED with default settings is closer in behavior to SIMPLE than PISO.
Using a large time-step and small URF is just not optimal (the small URF negates the large time-step). I think you just have general convergence / stability issues and the problem is not really about which scheme to use. But if you're going to use large time-steps, definitely don't use PISO. |
July 4, 2019, 07:16 |
Andrea
Rep Power: 6 |
Thank you for your answer, LuckyTran.
I have first run a Steady calculation and reduced the under-relaxation factors to get a stable solution. However the local Velocity field still changed slightly, so I continued with a large time step transient and frozen-flux formulation to further stabilize it. At your suggestion I would try bigger URFs. We have a complicated geometry/mesh and it is difficult to obtain a stable Steady state flow. I thought that a proper scheme would help the stability... Best, |
Using convergence manager for Transient simulation | lma80 | FLUENT | 3 | February 19, 2018 05:13 |
Convergence Criteria for first Timestep in transient run | aerost | CFX | 3 | February 19, 2013 04:01 |
transient case diverged all of a sudden after already convergence | wc34071209 | OpenFOAM Running, Solving & CFD | 2 | November 12, 2012 06:55 |
Convergence for a transient problem | jgrisham | FLUENT | 0 | July 17, 2012 11:47 |
Transient axial rotor/stator convergence issue? | Nicola Viscanti | CFX | 3 | March 17, 2010 04:15 |
