Number of equation by using eddy viscosity turbulence models |
August 3, 2019, 04:15 |
#21 |
Lucky
Rep Power: 66 |
The first is the definition of the turbulent kinetic energy k.
The second is a relation between k, epsilon, and the turbulent length scale (a pseudo definition). Note that a new unknown (the turbulent length scale) is introduced. Neither will directly help you determine k or epsilon nor the turbulent viscosity. You still solve transport equations for k and epsilon. Keep in mind the purpose of the turbulence model is not really about k or epsilon (or any fancy variables you can think of), but to get you the turbulent viscosity. |
August 3, 2019, 05:04 |
#22 |
Rep Power: 6 |
The main aim is the tubulent viscosity, that's clear.
But for what do i need the equations above? You don't do any definitions or equations just for fun. Are they for the calculation of initial values ? |
August 3, 2019, 05:38 |
#23 | |
Filippo Maria Denaro
Rep Power: 71 |
The hystorical turbulence model starts with a single relation without adding further PDE. Then, people tried to add more equations to the original model with the goal to obtain a more physical representation of the model. I remember some RANS formulation with dozens of supplied equations..... Have a reading to the Wilcox's textbook |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 06:00 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
