openFoam //thermal buoyancy on a double skin facade |
October 2, 2019, 03:19 |
Tobias
Rep Power: 7 |
I have a problem with a double facade. The goal is to find out the surface and air temperatures in the space between the panes. To simplify the problem and get a feeling for it there is no radiation and the surfaces get a fixed temperature.
Open atmosphere boundary conditions That didn't get me anywhere. I use OF 1806 with the solver buoyantSimpleFoam Had anyone a similar problem? Tobias Attached a picture of my case and BCs Thanks for helping |
July 1, 2020, 09:20 |
M. Salman Siddiqui
Rep Power: 11 |
Hi.
I am running into a similar problem, did you find solution? |
July 2, 2020, 02:40 |
Tobias
Rep Power: 7 |
its a long time ago, but try totalPressure for bottom, front and zeroGradint for Top and for U presuereInletOutletVelocity (0,0,0) for bottom, front and inletoutlet for top |
July 2, 2020, 11:16 |
M. Salman Siddiqui
Rep Power: 11 |
Hi.
thanks. Did you publish any article based on that research? I am working on CFD of double skin facades at present. My aim is to understand various thermophysical phenomenon, inside temperatures and flow profiles. Why did you use buoyantSimpleFoam against buoyantBoussineqSimpleFoam? Actually i am also using the former, because for my case the latter did not give me accurate velocity profiles inside the cavity. |
July 2, 2020, 11:18 |
M. Salman Siddiqui
Rep Power: 11 |
Hi.
If possible, can you share one case file of working case for reference? |
July 3, 2020, 02:33 |
Tobias
Rep Power: 7 |
that wasnt for research. This is a too planed building in which we wanted to estimate the influence of the facade on the cooling load. So I can't give you a case, sorry. I used the solver for the radiation. |
July 3, 2020, 06:01 |
M. Salman Siddiqui
Rep Power: 11 |
No problem. Did you integrate DSF with this complete building to understand/estimate the heating and cooling loads? I am at present performing 2D DSF simulation - to understand velocity and temperatures inside the cavity. I am also interested to understand how different configurations of the opening of top and bottom influence the flow. What could be the next step is to integrate the DSF with the complete building or neighborhood to understand how it affects the heating or cooling loads. Did you have any experience with this? |
OpenFOAM 4.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 2 | October 6, 2017 05:40 |
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin | CFDFoundation | OpenFOAM Announcements from Other Sources | 0 | January 4, 2017 06:15 |
Request for CFD help: Dynamic double skin facades | fadisami | CFD Freelancers | 2 | August 4, 2014 10:38 |
air flow simulation in double skin facade with openfoam | gygfei | OpenFOAM | 1 | December 20, 2010 04:50 |
what's wrong about my code for 2d burgers equation | morxio | Main CFD Forum | 3 | April 27, 2007 10:38 |
