October 21, 2019, 07:19 |
Auto smoother in Wildkatze flow solver
Savya
Rep Power: 6 |
I am trying a new flowsolver called Wildkatze. I am just a beginner with it.
I see in stree or simulation set up file an option called auto-smoother. This is for amg method. It also mentions gauss-seidel as an option. Does anyone know anything about "auto-smoother" and how it works. Thank you. |
October 22, 2019, 05:04 |
#2 | |
Arjun
Rep Power: 34 |
well auto smoother is as name suggest a automatic smoother - it decides by itself what to do.
Basically this is added for calculations that produce difficult or inconsistent linear systems. This can happen if the mesh is not good or have near negative cells. For example if a diagonal term = 0 appears and then you can not use regular smoothers like gauss seidel. (division by 0 will happen). In this case auto smoother shall work out. Use it if you have difficulty in convergence. Quote:
October 23, 2019, 10:51 |
#3 | |
Savya
Rep Power: 6 |
Is there any literature I can refer to about it?
Thank you for replying. Quote:
November 20, 2019, 04:33 |
Savya
Rep Power: 6 |
any comments??
Solver for an incompressible, turbulent flow with heat transfer | tH3f0rC3 | OpenFOAM Running, Solving & CFD | 9 | June 17, 2019 06:12 |
waveDyMFoam stability issue | goodster | OpenFOAM Running, Solving & CFD | 6 | September 23, 2018 04:40 |
[Other] OpenFOAM Installation for navalFoam | sachinlb | OpenFOAM Community Contributions | 22 | July 28, 2017 05:26 |
2 inlets with a different gas in each = a multiphase flow solver ? | adrieno | OpenFOAM Running, Solving & CFD | 2 | April 5, 2016 05:00 |
Inviscid solver : separation of the flow | Jean-Marie Cavet | FLUENT | 1 | September 2, 2003 12:32 |
