December 10, 2019, 02:39 |
Icem cfd - using the same blocking
Overijssel
Rep Power: 7 |
I am using ICEM CFD to mesh a single blade impeller of centrifugal pump. I managed to get a blocking for this pump. Now, I am trying to utilize the same blocking in my another geometry. Am I missing something? I am getting ' this (see screenshot) ' when I import the blocking into the new geometry. Thanking you. |
December 11, 2019, 06:54 |
#2 | |
Sebastian Engel
Rep Power: 20 |
HI SSapkota,
Hint: you likely need to rotate and scale the blocking to your new geometry, then reassociate. Ideally, you would also use the ansys meshing subforum for questions regarding ICEM. Best regards, Sebastian |
December 13, 2019, 02:37 |
reply
Overijssel
Rep Power: 7 |
Thank you for the reply. I am sorry. I should have been more explicit. By 'this' I mean to say that the blocking that I imported is not aligned with the geometry. Now, the geometry has a different size than the blocking. In that case, what would be the logical way to scale the blocking? Is it scaled according to the geometry scaling? Thanking you in advance.
December 13, 2019, 08:11 |
#4 | |
Sebastian Engel
Rep Power: 20 |
Start by opening the user's manual and search for "scale block". Then learn about the respective feature, and play with it until you understand it. I also suggest you to play with rotating blocks. After that the solution will become obvious to you. Of course this answer is without warranty of being the logical way |
CFD Online Celebrates 20 Years Online | jola | Site News & Announcements | 22 | January 31, 2015 00:30 |
3D geometry blocking in ICEM CFD. | Farhan ameer | ANSYS Meshing & Geometry | 1 | July 1, 2014 12:58 |
[TurboGrid] turbogrid to icem cfd then icem cfd to fluent | tmeysam92 | ANSYS Meshing & Geometry | 0 | May 7, 2014 06:25 |
Learn ANSYS ICEM CFD | easy_astronaut | ANSYS | 2 | December 15, 2013 15:34 |
[ICEM] Export unstructured periodic mesh from ICEM CFD to Fluent | ivanddd | ANSYS Meshing & Geometry | 1 | February 3, 2011 00:51 |
