January 12, 2020, 13:52 |
Simfow simulation, help needed
Kamilla
Rep Power: 9 |
I am trying to simulate the model in Simflow. This is protection cover in water with speed. As a result, I should get reaction forces and access distribution of flow around the cover. I am running model, it goes well however postprocessing is not perfect. i can not access threads (look at the flow around the cover) and in doubts if I can treat my model correctly. Would anybody have time to look at my model? I can send a file Thank you in advance Best regards, Kamilla Aitova |
help in analysis, outer water simulations, simflow help |
1D Heattransfare Simulation Excel-Help needed! | Skipper141 | CFD Freelancers | 3 | November 29, 2014 01:01 |
setting up a simulation with multiple interactions | phandy | OpenFOAM Running, Solving & CFD | 1 | October 6, 2014 03:16 |
Needed Help on Welding Simulation Process | darshankapadia | FLUENT | 0 | August 7, 2010 08:37 |
Blunt body aerodynamics simulation cases needed | David | FLUENT | 0 | June 1, 2003 11:40 |
Stirling engine simulation advice needed | Geoffrey | Main CFD Forum | 2 | December 18, 2001 02:26 |
