February 28, 2020, 12:57 |
Issue with cyclicAMI patches
Arun K Ampi
Hi All,
When I am trying to use CyclicAMI for my geometry, each time i keep on getting the same error. It would be great if somebody could help me to sort out this issue. Thanks in advance. --> FOAM FATAL ERROR: Unable to find initial target face From function bool Foam::AMIMethod<SourcePatch, TargetPatch>::initialise(Foam::labelListList&, Foam::scalarListList&, Foam::labelListList&, Foam::scalarListList&, Foam::label&, Foam::label&) [with SourcePatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>; TargetPatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>; Foam::labelListList = Foam::List<Foam::List<int> >; Foam::scalarListList = Foam::List<Foam::List<double> >; Foam::label = int] in file lnInclude/AMIMethod.C at line 129. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&)Found ignition cells: 1(233982) Ignition switched off Reading g Reading thermophysical properties Selecting thermodynamics package { type heheuPsiThermo; mixture inhomogeneousMixture; transport sutherland; thermo janaf; equationOfState perfectGas; specie specie; energy absoluteEnthalpy; } AMI: Creating addressing and weights between 16231 source faces and 16231 target faces --> FOAM Warning : From function void Foam::AMIMethod<SourcePatch, TargetPatch>::checkPatches() const [with SourcePatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>; TargetPatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>] in file lnInclude/AMIMethod.C at line 59 Source and target patch bounding boxes are not similar source box span : (20 12 0) target box span : (20 12 0) source box : (-10 -5 0) (10 7 0) target box : (0 0 2) (20 12 2) inflated target box : (-1.1661904 -1.1661904 0.83380962) (21.16619 13.16619 3.1661904) |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
time step continuity problem in VAWT simulation | lpz_michele | OpenFOAM Running, Solving & CFD | 5 | February 22, 2018 19:50 |
Case running in serial, but Parallel run gives error | atmcfd | OpenFOAM Running, Solving & CFD | 18 | March 26, 2016 12:40 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
problem with cyclicAMI and wall distance | Maff | OpenFOAM Bugs | 5 | August 14, 2014 14:41 |
