April 16, 2020, 16:54 |
smaller PSD at low and high frequency
niewiemnic
Rep Power: 8 |
https://drive.google.com/file/d/1XZ8...ew?usp=sharing
(please open the diagram in the link) hello, I do an aeroacoustic simulation for configuration of cylinder-naca0012. the location of microfone is somewhere in far field. As you can see the blue curve calculated relatively similar as the reference, but in the very low and high frequency (in diagramm Strouhal number) my results show much smaller PSD. Has someone similar experience as these results? + I used Curle's analogy and the reference FW-H. |
April 18, 2020, 10:34 |
niewiemnic
Rep Power: 8 |
https://docs.wind-watch.org/zajamsek...nteraction.pdf
I found a paper and if you see the figure 13, their PSD values which were calculated with Curle's Analogy also show not matched results in the low and high frequencies... Is Curle's Analogy not able to calculate correct SPL and PSD in the frequency areas? Last edited by spalartallmaras; April 18, 2020 at 12:28. |
BC for Actuator Disk - Flow Vel from High Pressure to Low Pressure | vinguva | OpenFOAM Running, Solving & CFD | 2 | March 7, 2016 23:46 |
replacing of shock tube high pressure part with a boundary condition for low pressure | immortality | Main CFD Forum | 0 | May 2, 2013 13:30 |
Will a multi-grid method damp out the high frequency physical wave? | hadesmajesty | Main CFD Forum | 8 | October 13, 2009 00:26 |
Reasons for failed validation at high frequency | zonexo | Main CFD Forum | 5 | October 23, 2006 09:32 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
