1D Burger's Inviscid Equation - MacCormak Scheme - Matlab Code |
May 4, 2020, 04:31 |
#1 | ||
Antonis
Rep Power: 6 |
Hello everybody.
I'm trying to learn some basic theory on CFD. Currently I'm studying the MacCormak scheme, I've read on wikipedia that it should give very accurate results in case of non linear PDEs so I'm trying it for the 1D Burger's Inviscid Equation. In the picture attached, the variables of matlab used in the code below are presented with the corresponding mathematical equation. In the second picture, you can see a graph of the solution with two methods: with MacCormak method and a simple forward in time, forward in space with CFL condition; it's clear that the former is pretty bad in contrast with the second method that seems pretty correct. Matlab Codes: --MacCormak Quote:
Thanks in advance for your time Last edited by zen3gr; May 4, 2020 at 09:27. |
May 4, 2020, 12:28 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
And you really want to learn the basic CFD reading wikepedia?? I strongly suggest to read non fundamental textbooks, you can find a lot of basic reading. For example, read this text and try to repeat the proposed test first on the linear wave equation then on the non linear Burgers equation. https://www.google.com/url?sa=t&rct=...5CwoG7Gt8UmeMX |
May 4, 2020, 12:58 |
#3 | |
Antonis
Rep Power: 6 |
Actually I'm reading the book by Anderson (Computational Fluid Dynamics, which covers, the very basic things required for a solid base) in combination with some video lectures for that purpose. I only quoted Wikipedia because it states that MacCormak should give satisfying results and that's not the case with my attempt. I would like a comment on the actual code. I'm gonna study the eBook you offered to get some more insight on the numerical schemes and try to troubleshoot it on my own. Thanks anyway, really appreciate your time! Last edited by zen3gr; May 4, 2020 at 15:56. |
May 4, 2020, 15:16 |
#4 | |
duri
Rep Power: 16 |
One of the method is wrong. Not sure which one because initial condition and time step is not given, I guess most likely simple is wrong. Plot the analytical solution and check the results. As initial step try to validate constant wave speed (Linear convection equation) and check that the initial condition have traveled exact distance on given time using x=ct relation. |
May 4, 2020, 15:44 |
#5 | |
Antonis
Rep Power: 6 |
I think the simple/CFL code captures the essence of phenomenon pretty correct. Time step is 0.025 for both cases as is the I.C. (u is everywhere 1 except some points that its value is two("hat" function), see attached graph). I've solved the linear convection equation before proceeding to the nonlinear case; I'm not sure how the bold text will help me with the implementation of maccormak. Thanks again for your time! |
May 4, 2020, 19:02 |
#6 | |
Antonis
Rep Power: 6 |
I've tried to solve 1d Linear convection equation with the maccormak scheme; it turns out I should have done it before attempting to solve the nonlinear one but I thought it would be too easy, that's not the case unfortunately.
In the pictures attached you can see the solution for two schemes: maccormak and a simple one with plain forward relations for time and space derivatives as well as the initial conditions and a interesting graph I found at Anderson's book about CFD and Heat Transfer about mathematical dispersion. I suppose that this kind of behaviour is typical for the second order MacCormak scheme (the wiggles of the solution compared to the simple scheme one). My question is: what can be done about it? Is something wrong with my code? Matlab Code: Quote:
Thanks in advance. Last edited by zen3gr; May 4, 2020 at 20:13. |
May 4, 2020, 22:54 |
#7 | |
Troy Snyder
Rep Power: 18 |
I have added an alternative implementation of MacCormack to your code below. It exhibits the dispersive (but non-diffusive) errors which you would expect. I think your implementation may have some subtle errors. Code:
clear all clc L=2; nx = 41; dx = L./(nx-1); nt = 70; %nt is the number of timesteps we want to calculate dt = .025; %dt is the amount of time each timestep covers (delta t) c=1; %IC u1 = ones(1,nx); u_pred = zeros(1,nx); u_pred(1) = c; u1(1,0.5/dx : 1/dx+1)=2; u_cfl=u1; u2 = u1; for t=1:1:15 u_p1=u1; u_p2=u2; u_cfl_p=u_cfl; for n=2:1:nx-1 %---MacCormak---% partial_t(n)=-(c/dx)*(u_p1(n+1)-u_p1(n)); u_pred(n) = u2(n)-c*dt/dx*(u2(n+1)-u2(n)); u_bar(n)=u_p1(n)+partial_t(n)*dt; derivative_bar(n)=-(c/dx)*(u_bar(n)-u_bar(n-1)); u1(n)=u_p1(n)+0.5*(partial_t(n)+derivative_bar(n))*dt; u2(n)=0.5*(u2(n)+u_pred(n)) - 0.5*c*dt/dx*(u_pred(n)-u_pred(n-1)); %---Simple FTFS scheme---% u_cfl(n)=u_cfl_p(n)-c*dt/dx*(u_cfl_p(n)-u_cfl_p(n-1)); end plot(linspace(0,2,nx),u1,linspace(0,2,nx),u_cfl,'r',linspace(0,2,nx),u2,'o') ylim([0 3]); legend('MacCormack','Simple FTFS','alt-MacCormack'); pause(.1) end |
May 5, 2020, 03:07 |
#8 | |
Rep Power: 71 |
You have a bug in the code. Even if Godunov theorem states that a linear second order scheme is not monotone, if you work on a smooth initial condition the numerical oscillations are disregardable. |
May 5, 2020, 04:06 |
#9 | |
Antonis
Rep Power: 6 |
clear all clc L=2; nx = 41; dx = L./(nx-1); nt = 70; %nt is the number of timesteps we want to calculate dt = .025; %dt is the amount of time each timestep covers (delta t) c=1; %IC u1 = ones(1,nx); u_pred = zeros(1,nx); u_pred(1) = c; u_bar(1)=c; u1(1,0.5/dx : 1/dx+1)=2; u_cfl=u1; u2 = u1; for t=1:1:15 u_p1=u1; u_p2=u2; u_cfl_p=u_cfl; for n=2:1:nx-1 %---ANDERSON_MacCormak---% u_bar(n)=u_p(n)-(c/dx)*(u_p(n+1)-u_p(n))*dt; derivative_bar(n)=-(c/dx)*(u_bar(n)-u_bar(n-1)); u(n)=u_p(n)+0.5*(-(c/dx)*(u_p(n+1)-u_p(n))+derivative_bar(n))*dt; %---MacCormak---% u_pred(n) = u2(n)-c*dt/dx*(u2(n+1)-u2(n)); u2(n)=0.5*(u2(n)+u_pred(n)) - 0.5*c*dt/dx*(u_pred(n)-u_pred(n-1)); %---Simple FTFS scheme---% u_cfl(n)=u_cfl_p(n)-c*dt/dx*(u_cfl_p(n)-u_cfl_p(n-1)); end plot(linspace(0,2,nx),u1,linspace(0,2,nx),u_cfl,'r',linspace(0,2,nx),u2,'o') ylim([0 3]); legend('MacCormack','Simple FTFS','alt-MacCormack'); pause(.1) end Thanks! Last edited by zen3gr; May 5, 2020 at 05:52. |
May 5, 2020, 06:52 |
#10 |
Rep Power: 71 |
Be aware that on the liner wave equation you should get exactly the Lax-Wendroff scheme. Try that a compare the results. |
Problem with Velocity Poisson Equation and Vector Potential Poisson Equation | mykkujinu2201 | Main CFD Forum | 1 | August 12, 2017 13:15 |
Conceptual Question about One Dimensional Inviscid Burgers Equation | tanmayagrawal7 | Main CFD Forum | 3 | May 20, 2015 09:50 |
First order upwind scheme for stationary continuuity equation with vortices | CerpinTaxt | Main CFD Forum | 8 | May 19, 2015 13:25 |
MATLAB Code | slimmsk | Main CFD Forum | 0 | October 17, 2012 11:02 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 15:56 |
