Artificial Diffusion
Like Tree2Likes
  • 2 Post By FMDenaro
Old   May 5, 2020, 10:11
Default Artificial Diffusion
Mudit Mehta
Mudit2208 is on a distinguished road
Hello, I want to know how to show the effect of artificial diffusion by using first order Upwind scheme for convective terms?
Mudit2208 is offline   Reply With Quote
Old   May 5, 2020, 11:05
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Use the linear wave equation, discretize using a first order explicit time integration and write the modified equation
vesp and Mudit2208 like this.
FMDenaro is offline   Reply With Quote
Old   May 5, 2020, 11:15
Mudit Mehta
Thanks for your reply. But i am solving steady state Navier stokes equation for Lid driven cavity problem. I am required to demonstrate the effect of artificial diffusion using first order upwind scheme for convective terms. Could you please help me with this?
Old   May 5, 2020, 11:29
Show the expression of the local truncation error of the discretization of the convective term. What term is present? What is the meaning in terms of the physics you are solving?
Old   May 5, 2020, 19:53
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Two possible ways are:
1) Use second order as well and compare the two
2) Solve for a flow with analytical solution and detect the actual viscosity given by the numerical solution
In both cases it is required to work at fixed mesh size, otherwise the numerical viscosity would change
sbaffini is offline   Reply With Quote
navierstokes cfd, python, simple algorithm
Problem simulating the temperature rise in a composite material (chtMultiRegionFoam) Adam_K OpenFOAM Running, Solving & CFD 2 March 27, 2019 06:51
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
numerical scheme without artificial diffusion artifact mpeti OpenFOAM Running, Solving & CFD 2 October 26, 2011 11:36
Any example of artificial viscosity artificial diffusion in OpenFOAM dbxmcf OpenFOAM Running, Solving & CFD 0 July 28, 2008 20:52
Artificial numerical diffusion Valdemir G. Ferreira Main CFD Forum 8 February 3, 2000 13:31
